93 vx d15z1 to a jdm d15b
iam buying a jdm d15b and i was wondering can i still use my harness and headers tranny axels and everything except ecu i have a 93 vx d15z1vtec e
Modified by p3terson17 at 8:51 PM 8/7/2007
You can use everything basically off your old motor, but if your going to use vtec your going to need a new ECU and harness bc I dont think the VX comes with vtec. GL
i know you will beable to use your vx harness but you will have to rewire the o2 sensor. The d15z1 uses a 5 wire 02 sensor where as the jdm d15b uses a 4 wire o2 sensor, it been awhile since i've messed with that so u may want to search up on that. everything else that you listed will work for you swap. ...hope that helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg6hybrid92 »</TD></TR><TR><TD CLASS="quote">i know you will beable to use your vx harness but you will have to rewire the o2 sensor. The d15z1 uses a 5 wire 02 sensor where as the jdm d15b uses a 4 wire o2 sensor, it been awhile since i've messed with that so u may want to search up on that. everything else that you listed will work for you swap. ...hope that helps</TD></TR></TABLE>
EDIT the jdm d15b use's a 1 wire JDM o2 sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p3terson17 »</TD></TR><TR><TD CLASS="quote">yea the vx comes with vtec e can i still use the harness??</TD></TR></TABLE>
Its plug and play the harness needs no modification for VTEC on the d15b it only needs modification for the o2 sensor, but I got by without rewiring from 5 wire to 4 wire on my d16z6 swap using the vx harness. But I get a CEL for it not sure if its bad but it works fine for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">move one wire on the VX side of the shock towers and the D15B will plug right in.
the one wire is for the O2 signal.</TD></TR></TABLE>
Could you explain this further?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95vxtealhatch »</TD></TR><TR><TD CLASS="quote">
Could you explain this further?</TD></TR></TABLE>
move C129 pin 6 to C102 pin 2
link to my site --> http://www.b18c5eg.com/itr_vx_wiring.html
tuan_turbo_dc4
Dec 13, 2003 05:51 PM
1990hondaHF
Aug 8, 2003 01:50 AM
