b18c1 vs b18c5
Old Aug 7, 2007 | 05:35 AM
kiklo16's Avatar
Default b18c1 vs b18c5
I currently have a b1 with in my 94 ls but i was thinking about doing an engine swap sometime within the next year. I need some opinions if i should go with the c1 or c5 and why. And which one would be better to boost. Thanks
Old Aug 7, 2007 | 05:40 AM
93dagsr's Avatar
go with a c1 for a dd and buy an ls and boost her! thats what im doing!
Old Aug 7, 2007 | 05:41 AM
PrinceAli132's Avatar
Default Re: b18c1 vs b18c5 (kiklo16)
You shouldn't have a problem boosting either one, as long as you get a good tune afterwards.
Ali
Old Aug 7, 2007 | 05:47 AM
vladd's Avatar
c1 is generally better for turbo because of the lower cr and milder cams. either one will work though.
Old Aug 7, 2007 | 06:44 AM
AWD Terror's Avatar
Default Re: b18c1 vs b18c5 (vladd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vladd &raquo;</TD></TR><TR><TD CLASS="quote">c1 is generally better for turbo because of the lower cr and milder cams. either one will work though.</TD></TR></TABLE>
Old Aug 7, 2007 | 07:03 AM
posHonda's Avatar
either one will work and boosted on a stock block will put out similar numbers reliably sooo get the gsr.
Old Aug 7, 2007 | 08:16 AM
Turbo-GSR1287's Avatar
Default Re: (iVteC_PoWeR)
Like the others said both work quite well with boost, but if you plan on boosting you might as well as just get the C1 and boost it because C5 motors are quite a bit more expensive then the GSR motor.
Old Aug 7, 2007 | 10:40 AM
nautica_t's Avatar
doesn't matter what motor you plan to use, but its your budget that should tell the story not which one is better.
Old Aug 7, 2007 | 10:43 AM
JDM_CRX_PLEASE's Avatar
just boost ur LS
Old Aug 7, 2007 | 10:44 AM
MadVtak's Avatar
* B A N N E D *
From: Biggest Baddest Little City in The World RENO, NV
Either boost your ls, Boost a gsr
Type-r's are too overrated to me
Old Aug 7, 2007 | 01:51 PM
thewrai6th's Avatar
Default Re: (MadVtak)
C5 is higher compression, better for NA. C1 is better for boost, but has the secondary runners on the intake that don't open until 6K.
I don't think the milder C1 cams are better for boost than the C5 cams. I've seen dyno gains on a boosted setup, just from adding in the ITR cams.
Why not just boost the LS?
uhhmaysing
Feb 17, 2014 09:35 PM
ssmrico
Jul 24, 2008 07:36 PM
ghostofnyc
Dec 26, 2007 12:49 PM
scspeed
Dec 25, 2007 09:11 PM
HS2G
May 30, 2004 06:11 AM
