Injectors not working?
Old Aug 6, 2007 | 05:41 PM
Dyno247's Avatar
Default Injectors not working?
Well as some people know, i blew up my b18c from idiotic reasons. So i went ahead and bought a b16a longblock. In the process of rewiring a few things and putting the motor in, i ran into a problem.
I installled the turbo kit that i used on my b18c on my b16a. Everything work fine and the injectors worked too when my b18c was running. So i try to start the car up, but it doesnt. I get compression, spark, but no fuel. Now i hear my fuel pump prime and i get fuel threw my FPR. But i dont get any fuel into my injectors. Im using DSM 450cc injectors and wired up the resistor box. Also keep in mind that it worked fine on my b18c.
First off i checked over the wiring and thats fine. Then i checked too see if i get an voltage and i do. I also tryed to see if my stock b16 injectors would work, but they dont. i get fuel pressure too. Anyone know whats wrong or have this happen to you?
Old Aug 6, 2007 | 09:01 PM
Dyno247's Avatar
Default Re: Injectors not working? (Dyno247)
bump!! need my car to run!
Old Aug 6, 2007 | 09:05 PM
Ramma's Avatar
You could use an injector test light, it should plug right into the injector plug and light up when you try to start the car. All your grounds good?
Old Aug 8, 2007 | 09:49 AM
Dyno247's Avatar
Default Re: (Ramma)
Hmm.. my grounds for my injectors are good, but in my other thread i think it could be my thermostat ground. Where would i find this ground for my thermostat? thanks for the help so far.
Old Aug 8, 2007 | 07:46 PM
Dyno247's Avatar
Default Re: (Dyno247)
Well checked my ground and i do have my thermostat grounded. hmmm.. any other ideas? help please!?
Old Aug 10, 2007 | 06:59 PM
Dyno247's Avatar
bump for more info!
turbodailydan
May 28, 2009 01:38 PM
dcCale
Aug 14, 2008 09:03 PM
Dyno247
Aug 10, 2007 06:58 PM
EGHatchy
Jul 14, 2002 11:25 AM
turbopanda
May 1, 2002 01:24 AM
