Vtec problems in a H22 EK
Old Aug 5, 2007 | 06:49 PM
JDMPWRD's Avatar
Default Vtec problems in a H22 EK
Hi...
I have a jdm h22 motor in a 97 CX and i've been having weird problems with the Vtec ever since the swap.
Everytime i turn the car on there is no vtec as long as the car is "cold"... once the temperature gauge gets high(first line) i have to cut the car off and back on then MAGIC.. Vtec is there.
please help me figure this out guys..
Thank you
P.S the ecu is a stock JDM h22 ecu.. obd1
Old Aug 5, 2007 | 07:02 PM
cool_junk's Avatar
Default Re: Vtec problems in a H22 EK (JDMPWRD)
Have you tried another puter? That is the only thing that controls it. any aftermarket chips?
Drew
Old Aug 5, 2007 | 08:10 PM
slowcivic2k's Avatar
Coolant temperature needs to be at a specific point before it will engage, it will not engage cold, unless you have a chip that turns it on at a specific point all the time.
Old Aug 6, 2007 | 04:36 AM
JDMPWRD's Avatar
Default Re: Vtec problems in a H22 EK (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">Coolant temperature needs to be at a specific point before it will engage, it will not engage cold, unless you have a chip that turns it on at a specific point all the time.</TD></TR></TABLE>
understandable, but the thing that gets me is that it won't come on by ITSELF when the car is warm, i have to switch the car off then back ON in order to get it to work.... i have a P28 and Hondata stage 2 but i haven't had time to put that in and go tune the car... because i know with that setup i can bypass all the VTEC bullshit...
so nothing else you could think of that might be behind this?... i never had to do that when i had a JDM h22 in my prelude...
thanks for the input guys...
Old Aug 6, 2007 | 01:40 PM
JDMPWRD's Avatar
bump!!!!!
Novtecdohc
Nov 15, 2006 09:16 PM
lsvtecndx
Oct 10, 2006 06:18 PM
window44
Mar 11, 2005 11:05 AM
H22A_HB
Aug 23, 2004 04:05 PM
Maintenance
Aug 13, 2003 08:45 AM
