p06 auto to manual mod!
Old Aug 5, 2007 | 05:59 PM
cool_junk's Avatar
Default p06 auto to manual mod!
I have a 93 cx hatch that I did a d15b7 engine swap to and had to get a p06 ecu, so I found one in the bone yard but it was out of an automatic car. so of course the engine light was on with codes 41 (o2 heater) and 19 (tcc solenoid), I put a heated o2 in it and wired that up which did away with that code. But I still had the 19, so I ohm'd out the tcc solenoid that I had lying around and went to radiocrack where I got two 15ohm resistors which I soldered inside the computer to one between pin 17&ground and the other between pin 19&ground of the 26 pin connector. Fixed the problem! NO MORE LIGHT!!! if you have any questions feel free to ask.
Later, Drew
Old Aug 5, 2007 | 06:08 PM
cool_junk's Avatar
Default Re: p06 auto to manual mod! (cool_junk)
I would have posted pics if I could find a free way to host them.
Drew
Old Aug 5, 2007 | 11:30 PM
ej8's Avatar
ej8
You could have just removed RP17 and put a jumper on RP18 and done the same thing This is how you convert an automatic to manual, you are not simulating a sensor by doing it this way
Good job thou
Old Apr 18, 2022 | 03:05 AM
bangel's Avatar
Later, Drew
Pls help me i have the same problem po6 ecm that have 41 trouble code, ilook at my headers it has no oxygen sensor and wire, i want ti wire it from the ecm to headers my i now what pin number is the primary oxygen sensor thnks
ugh
19
Apr 13, 2009 11:23 AM
h22honda89
10
Aug 19, 2007 02:40 PM
cool_junk
Aug 7, 2007 07:50 AM
imsquisht
Jul 16, 2007 08:19 AM
ProJectCvic
Sep 17, 2003 02:42 PM
