HELP! Axle problems with innovative h22a mount in EG
I used the innovative mount kit for my h22a into an eg and my axle is binding on the tranny side. I even bought the axles innovative sells on their website and it still binds. I've used DA axles too and have no problem with the driver side just the tranny side. The car is not even lowered, stock height. Has anyone had any experience with these mounts? What axle combination did you use? NEED to get my car rollin again. Thanks.
after the axle spline has been passed through the hub and all the suspension is bolted up (axle nut is off), there should be about a half inch of back and forth play...do you have that or is the axle very tight in the hub?
No i dont have that half inch of play. It does that on the driver side but the passenger tranny side is super tight. I'm just real frustrated because i have the axles innovative sells on their website that are supposed to work with their kit and they don't. DA axle is a little bit better but also does not work. I can't figure out where the problem is. Thats why I was hoping someone has the kit for an eg and can tell me what axles they run.
So you had the innovative mounts for h22a into an EG? On the tranny side mount, where did you line up the mount? Was it the two 14mm holes on the bottom of the frame rail? And were you running the innovative axles or another kind? Thank you.
Finally!!! I'm able to reply. The car has been lightly hit but the only damage was to the hood, bumper, and driver headlight. There was NO frame damage at all. i had a GSR in there with absolutely no problems at all. I'm thinking that Innovative sent me the wrong size axle because the one they sent was even worse then the DA axle that only slightly binds. Mainly I NEEDED to get reasured that other people have ran the Innovative mount kit with their axles with NO trouble. Let me ask you this though...did you have to chop off the factory tranny mount to make the innovative mount fit? Thank you.
Has anyone else used the innovative mount kit with no problems? Also anyone know of a factory axle combination to use with that set up?
cliffy v
Aug 17, 2007 09:30 PM
