Oil cooler
Old Jun 11, 2002 | 12:55 PM
xci_ed6's Avatar
Default Oil cooler
I got a new radiator, and it is the one for the auto with the tranny cooler. Can I use it for an oil cooler, and how?
-Dustin
Old Jun 11, 2002 | 01:14 PM
Urban Business
Guest
Posts: n/a
Default Re: Oil cooler (Autocratic_1st_Gen)
youd just have to run your lines to and from it.
Old Jun 11, 2002 | 01:46 PM
FredoTheChimp's Avatar
really does it come with the cooler or you pay extra?
Old Jun 11, 2002 | 03:23 PM
xci_ed6's Avatar
Default Re: Oil cooler (Accord92sir)
$100 shipped from ebay brand new w/ lifetime warentee. If you get the 26" core it comes with the trans cooler, I think it is easier when they only have to stock one kind of radiator. Where do I run the line from?
-Dustin
Old Jun 11, 2002 | 11:53 PM
travis's Avatar
-Dustin
To answer your question, the fastest and easiest way to run lines for an oil cooler is to get a sandwich adapter plate between the oil filter and the block. You will need the adapter, enough hose to reach from the adapter to the cooler and back, and hose fittings. I suggest SS braded hose and Earl's fittings for anything on the oil system. Be extra careful how you route them, too, so that they can't slip into moving parts.
The other way to connect it (I did this in the race car) is to get a block adapter that just has hose in/out on it and run it to a remote oil filter location. The advantage is that you can run a larger oil filter, you can connect gauge senders easily, and you can run an oil cooler in the line too. The down side is that it is a little more expensive.
Now answer a question for me. Exactly what radiator did you buy off of ebay that came with an integrated transmission cooler? I need to replace my radiator, and this would save me the immediate need to buy the oil cooler. Can you give me a link to an auction (even an ended auction) so that I know what to look for? Thanks!
Old Jun 12, 2002 | 04:17 AM
Mista Bone's Avatar
D Tranny Guru
-Dustin
No, it doesn't have enough flow capacity
Old Jun 12, 2002 | 01:50 PM
xci_ed6's Avatar
Default Re: Oil cooler (Mista Bone)
damn...are you sure?
-Dustin
Old Jun 12, 2002 | 07:31 PM
Mista Bone's Avatar
D Tranny Guru
well if I wasn't sure I would not have posted.
Old Jun 13, 2002 | 06:40 AM
CRXRageD's Avatar
well there is a problem with your idea, one there isn't enough surface area from the automatic tranny oil cooler to cool the actual engine oil. It's also counter active if you think about it. If you are cooling off a possible 600degree engine oil while trying to keep your coolant cooled off, you will be essentially be heating up the water because of the heat transfer. you may see a little reduction but the purpose of the radiator is to cool the coolant/water by displacing it along the radiator fins which the oil will never see. if you put the hot oil under it, you will just heat the coolant up. It's not a great idea, even on some stock cars with the AT fluid circulating through, I doubt the AT fluid will see nearly as much engine temperatures though.
Old Jun 13, 2002 | 09:55 AM
N24RE's Avatar
Default Re: Oil cooler (CRXRageD)
__________________________________________________ ________________
HOLY COW...600 degree engine oil......what kind of engne you got? A rocket engine?
Back on topic....just buy an oil cooler if you need it....you will never get enough flow from the tranny cooler to keep your engine lubed
Check out my sig for pics of my Rs oil cooler
Ciao
d16z6head
Aug 30, 2008 07:47 AM
mattmw88
Oct 11, 2004 09:54 PM
done
Aug 2, 2004 08:50 AM
kablamo
Jul 20, 2004 02:42 PM
leprechan117
Apr 27, 2003 06:33 AM
