might have spun a bearing
Old Aug 3, 2007 | 12:04 AM
hidiouskinky's Avatar
Default might have spun a bearing
ok guys i have a b18c1 right now the head is off because of the noise the motor was making i thought it was valve related its not i removed the oil pan and there r metal shaving in the pan could it b from a spun bearing and if so what is involved in replacing it
Old Aug 3, 2007 | 12:10 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: might have spun a bearing (hidiouskinky)
Were you low on oil???
Old Aug 3, 2007 | 12:31 AM
Default Re: might have spun a bearing (Project95LS-VTEC)
there was some on the stick but i didnt think it was enough to do that im just curious as to how hard of a swap out will it be it will b me and my father-in-law which rebuilds motors all the time
Old Aug 3, 2007 | 06:24 PM
anybody anybody any help would b appreciated i looked in the FAQ's and nothing about spun bearings
Old Aug 3, 2007 | 08:06 PM
toolfan020's Avatar
I just purchased a 99 gsr cheap that had a motor with a spun rod bearing. The head is fine, but we are rebuilding the bottom end with new badass pistons, rods, etc... The reason why it happened was related to the oil pan being welded back on poorly by the previous owner I believe Goodluck with fixing it!
Old Aug 3, 2007 | 08:11 PM
Lauj87's Avatar
What kind of noise was it making before you started tearing everything apart? was it just ticking or was it knocking? My brother had a spun bearing it was knocking like crazy.
Old Aug 3, 2007 | 09:10 PM
g2daturbo's Avatar
Default Re: (Lauj87)
ive put bearings in cars without removing the engine as long as the crank isnt damaged... bearings are not hard to do but a perfect time to freshen up the whole engine
Old Aug 3, 2007 | 11:42 PM
Default Re: (g2daturbo)
thats what we r doing a week before this happened i put a skunk2 pro valvetrain so with this problem im going to just put new rings and make sure the ring landings r good im boosting in the future but i dont want to put low compression pistons in now or since i have to put new pistons in later should i just go with high comp pistons now would that really matter to the performance of the car but yea im putting eagle rods in pretty much everything except new pistons....unless high comp pistons would b good for my car now hmm....ill leave that for another post
Old Aug 4, 2007 | 09:11 AM
toolfan020's Avatar
Default Re: (hidiouskinky)
Yea im going with the eagle h beam rods, I would say go with Je 11:1.1 compression pistons new proseal rings etc... buying them in a kit is usually cheaper. You can expect maybe 15 -20 hp gain running the higher compression like that on 93 octane. Make sure your crank is good too, gaskets etc. Good luck!
Old Aug 4, 2007 | 11:16 AM
Default Re: (toolfan020)
the crank is still in good condition and since everything is pretty much pulled apart ill b putting on new gaskets and all the goodies
Old Aug 4, 2007 | 07:46 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hidiouskinky &raquo;</TD></TR><TR><TD CLASS="quote">thats what we r doing a week before this happened i put a skunk2 pro valvetrain so with this problem im going to just put new rings and make sure the ring landings r good im boosting in the future but i dont want to put low compression pistons in now or since i have to put new pistons in later should i just go with high comp pistons now would that really matter to the performance of the car but yea im putting eagle rods in pretty much everything except new pistons....unless high comp pistons would b good for my car now hmm....ill leave that for another post </TD></TR></TABLE>
if you're going to boost in the future just get stock cr pistons. while higher cr pistons will give you more power now they'll force you to cut down on the boost later.
Old Aug 5, 2007 | 05:59 PM
Default Re: (vladd)
but if im changing the pistons later to low cr pistons anyway wouldnt i benefit, at least for now, with high cr pistons.....because im doing one of two things im either going to put new rings on my exsisting pistons or put high cr pistons in i just figured i would b better off now with the high comp pistons....right or is that a newbie way of thinking
Old Aug 7, 2007 | 05:46 AM
vladd's Avatar
if you wana waste the money to get new pistons and retune your engine then go for it. it's your car.
Old Aug 7, 2007 | 03:17 PM
Default Re: (vladd)
as far as retuning goes i have a chipped p28 sitting in the garage and i think that this would b the perfect time to put it in wouldnt u think
Old Aug 8, 2007 | 05:37 AM
vladd's Avatar
what kind of chip? is it an ebay chip, or a socket and reburnable chip? if it's an ebay chip, throw it away. if its a socket and reburnable chip, then you'll need to tune the ecu every time you change pistons for max power.
Old Aug 8, 2007 | 11:13 AM
Default Re: (vladd)
LOL i try to stay away from ebay theres a motorsports shop near me that has them and my mech can tune it i was thinking that after i put the boost to it that ill need to retune anyway so this way i can get the little extra power now and THEN later as well
Old Aug 9, 2007 | 06:35 AM
vladd's Avatar
its your money, do whatever you want. i wouldn't waste the money for pistons and a tune that'll be thrown away in the near future.
Old Aug 9, 2007 | 07:43 AM
GSR-C5's Avatar
gwt new rings, using the old rings is just stupid. you already have it out and the sound of things you have money to waste
i would just go with lowered cr piston and new rods and rings now. less work later.
Old Aug 9, 2007 | 08:00 AM
MeanGreenMachine's Avatar
Default Re: (vladd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K-ITR &raquo;</TD></TR><TR><TD CLASS="quote">gwt new rings, using the old rings is just stupid. you already have it out and the sound of things you have money to waste
i would just go with lowered cr piston and new rods and rings now. less work later. </TD></TR></TABLE>
+1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hidiouskinky &raquo;</TD></TR><TR><TD CLASS="quote">there's shop near me that has them and my mech can tune it </TD></TR></TABLE>
corr performace tuning maybe??? that the shop u talking about?
meuby
May 18, 2010 04:56 PM
thewrai6th
Oct 25, 2009 11:22 AM
b16a1eg6
Oct 25, 2007 11:23 AM
Combustion Contraption
29
Apr 25, 2005 05:50 PM
Unsivil_audio
Jan 19, 2005 11:23 AM
