help!!!!!!!!!!!!!!!!!!!!!!!vtec problem
Old Aug 2, 2007 | 01:10 PM
d16z6ef's Avatar
Default help!!!!!!!!!!!!!!!!!!!!!!!vtec problem
i just did a LS Vtec turbo and i put gsr cams we checked the vtec is geting oil the computer us sending the vtec signal i was just woundering i anyone had this problem before
Old Aug 2, 2007 | 01:20 PM
BlackoutVTi's Avatar
Default Re: help!!!!!!!!!!!!!!!!!!!!!!!vtec problem (d16z6ef)
K....What is the problem with your VTEC then?
Old Aug 2, 2007 | 01:24 PM
d16z6ef's Avatar
the vtec doesnt engage at all
Old Aug 2, 2007 | 01:25 PM
Syndacate's Avatar
Default Re: (d16z6ef)
Jump the VTEC solenoid power wire to the battery and see if it clicks.
If it's sending the signal and the VTEC solenoid is working - it's engaging.
Old Aug 2, 2007 | 01:26 PM
Default Re: (Syndacate)
Yep. Use the jumper method to see if it is functioning.
d16z6ef's Avatar
yeah it clicks but i dont feel the affect
Old Aug 2, 2007 | 01:29 PM
d16z6ef's Avatar
i also ran a wire from the computer to the vtec solenoid
Old Aug 2, 2007 | 01:33 PM
d16z6ef's Avatar
you think the cams are thowing it off
VTEC is not too drastic in stock applications (ie: INSTANT TURBO). If you need your confidence in VTEC restored, roll up your windows, turn off your music and your fan, and do a second gear pull from low RPM to high on a straight road. Pay attention to where VTEC is supposed to engage, and you may just hear it. Otherwise, I don't know what to tell you. You may be deaf.
What head are you running with those GSR cams?
Old Aug 2, 2007 | 01:42 PM
d16z6ef's Avatar
b16 head with gsr cams it sounds like it but it is just the waste gate opening
Old Aug 2, 2007 | 02:12 PM
Did you hear it just fine with the original b16 cams in it, or did you not have them to begin with?
Either way, the stock VTEC has probably been overshadowed by your turbo setup. If you want aggressive enough VTEC to really notice, look into some performance turbo cams and tune it again.
Old Aug 3, 2007 | 06:36 AM
d16z6ef's Avatar
bump
willem
16
Feb 19, 2012 04:07 AM
92 bandit
Aug 24, 2006 09:04 AM
lmiguelvv
Oct 19, 2004 06:55 PM
xvracing
May 1, 2004 01:49 PM
SpeedGyrl
Mar 16, 2003 04:23 PM
