Mystery motor.........
Old Aug 2, 2007 | 12:14 PM
dizzzane's Avatar
Default Mystery motor.........
i made a thread a few weeks back about help trying to identify a motor that we got on a shipment. The problem was that the serial code was shaved off... but we do know this now.... its a b18c, has a type r head/intake manifold/throttle body, but gsr rods, unsure of pistons. has a y80 cable tranny. Has a p73 ecu but has some sort of piggyback wired in as well. what we are thinking is that its a gsr bottom, type r top and was in a pre 1992 civic/crx (cable tranny). Assuming the pistons are gsr, will this motor make "type-r like" numbers........ just looking for some input or past experience
Old Aug 2, 2007 | 12:18 PM
goota's Avatar
talk about a frankenstien
Old Aug 2, 2007 | 12:34 PM
dizzzane's Avatar
Default Re: (goota)
yea man im sure some japanese dude customed it out... its almost impossible to tell what exactly it is.. better hit the dyno
Old Aug 2, 2007 | 12:46 PM
thewrai6th's Avatar
Default Re: (JDM_dc2_B18c)
I guarantee that at some point that block was stolen. I don't know about NC, but here in CA, you will not ever get your car back from the cops for having shaved SN's.
PACT man's Avatar
Could have been in a DA Integra also(they use cable trannies). If it has the stock GSR pistons it probably wont make the same power as the Type-R, it wouldn't have as high compression, if it had the Type-R pistons it would probably be pushing around the 11.4:1 compression ratio making it very much like the Type-R.
Old Aug 2, 2007 | 12:49 PM
dizzzane's Avatar
Default Re: (PACT man)
well these are (at worse case) jdm gsr pistons, which would be 10.6:1, as opposed to the 11.1:1 for the R, i didn't know if that alone would cause a sufficient difference.
Old Aug 2, 2007 | 12:53 PM
dizzzane's Avatar
and yea, it may have been in a DA, but i didn't think the motor mounts would be the same
Old Aug 2, 2007 | 01:51 PM
Blahblah718293's Avatar
why would you ever shave off a s/n or vin or anything of that matter unless it is stolen?
Old Aug 2, 2007 | 01:52 PM
Kyle R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_dc2_B18c &raquo;</TD></TR><TR><TD CLASS="quote">i made a thread a few weeks back about help trying to identify a motor that we got on a shipment. The problem was that the serial code was shaved off... </TD></TR></TABLE>
Old Aug 2, 2007 | 02:13 PM
91redteg's Avatar
Default Re: (Blahblah718293)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 &raquo;</TD></TR><TR><TD CLASS="quote">why would you ever shave off a s/n or vin or anything of that matter unless it is stolen?</TD></TR></TABLE> x2
Old Aug 2, 2007 | 02:15 PM
lsvtecboi'95's Avatar
i accidently rubbed some of my vin off when i was cleaning the block like 2 weeks ago using the green side of the spouge... all i could say was ohhh ****..
if it is completely shaved it has to be stolen at some time
Old Aug 2, 2007 | 02:19 PM
B_CRUZ!'s Avatar
If it was a shipment from Japan then most likely it wasn't stolen. If it was from the U.S., then it is HOT.
Old Aug 2, 2007 | 02:37 PM
thewrai6th's Avatar
Default Re: (B*CRUZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B*CRUZ &raquo;</TD></TR><TR><TD CLASS="quote">If it was a shipment from Japan then most likely it wasn't stolen. If it was from the U.S., then it is HOT. </TD></TR></TABLE>
Please explain your thinking there. Why would it be normal for the VIN/SN to be shaved if it's from Japan? That just makes me think it was first stolen in Japan. Either way, don't get caught driving that in CA.
Old Aug 2, 2007 | 05:39 PM
dizzzane's Avatar
Default Re: (thewrai6th)
he is right it did come from japan, it came in a shipment and i don't know if it was scratched off when the owner was in japan purchasing it... it takes like 3 months to get it from japan to us. we put a serial number on it, but aren't selling it, one of the owners will probably take it.
2Nyce
Nov 9, 2010 11:19 AM
dizzzane
Jul 13, 2007 12:45 PM
x8_andrew_8x
Apr 29, 2007 01:36 PM
01-0720
Apr 19, 2002 07:38 AM
01-0720
Apr 19, 2002 07:37 AM
