Running a B18c with TWM ITB's.. what throttle cable do i use?
Old Aug 2, 2007 | 10:02 AM
fortynineR's Avatar
Default Running a B18c with TWM ITB's.. what throttle cable do i use?
ive heard of many different problems about the itbs not opening up full throttle..
anyone have this issue?
Old Aug 2, 2007 | 02:09 PM
EF_LSVtec's Avatar
Default Re: Running a B18c with TWM ITB's.. what throttle cable do i use? (fortynineR)
I reused my old throttle cable (LS)...Only problem that I have with the itb's is that it doesn't fully close after I release the pedal...kinda sticking, so we just put an extra return spring. It opens up just fine.
Old May 31, 2009 | 06:50 AM
ef2hondaboi's Avatar
yea i just started to have this problem with my fully built b16 itb set up. I'm running the twm ones. i was running my stock b16 cable until i call up twm and they told me that i need to run the gs-r cable. still the same **** after swap cables..still doesn't open full throttle..anyone with help i appreciate.
Old Oct 4, 2009 | 07:39 PM
B-B-K's Avatar
I just installed some TWM ITB's on my LS-V and having the same problem. Im going to wire up my TPS tomorrow and see what that reads when I press the pedal to the floor. Anyone come up with an answer?
Old Oct 7, 2009 | 11:33 AM
there is a thing on the bacc of the pedal and you gotta cut that off. after you cut that off you can start adjusting the cable wire so it can full throttle. lmk if this works. cuz it work for me.
Old Jul 22, 2011 | 02:32 PM
ht023's Avatar
are you talking about the bushing on the back? (pedal side)
jord18
Apr 1, 2010 04:26 AM
Mr. Em1
Apr 21, 2007 08:23 AM
Axemurderer23
Jun 14, 2004 06:12 AM
mixmastabob
Aug 1, 2003 11:09 PM
