how to hook up auto gage tach
black - ground (chassis)
green - rpm signal (blue wire behind cluster or at distributor or at ecu)
white - illumination (dimmer switch)
red - 12v +
red - 12v +
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatthisspeed69 »</TD></TR><TR><TD CLASS="quote">wat wire on the dizzy to u run the green wire too...and where do you run the white wire too</TD></TR></TABLE>
anybody know where these wires go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatthisspeed69 »</TD></TR><TR><TD CLASS="quote">wat wire on the dizzy do u run the green wire too...and where do you run the white wire too</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker »</TD></TR><TR><TD CLASS="quote">black - ground (chassis)
red - 12v + </TD></TR></TABLE>
Did you not see that?
From: Where the wild things are in, NY, United States of America
If you're going to run the tach off the distributor, you need to splice into the blue wire with the white tracer (or blue/white wire). thats the tach signal. The white one goes to any wire that illuminates something on the dash ( something for the heater controls would probably be easiest ).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatthisspeed69 »</TD></TR><TR><TD CLASS="quote">i dont have a blu/wht wire on my dizzy i have a wht/blu and just a plain blue but not blu/wht</TD></TR></TABLE>
you're making this way to hard..
On the distrubutor theres 2 wires together away from the other wires,,1 is blue,tap into that for the rpm signal..
or like i said use the same blue wire behind the cluster,or the blue wire at the ecu pins..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">RICER TACH FOR THE WIN!
BEST THREAD LAUGH EVER! </TD></TR></TABLE>
I need a 19 incher, like Flavor Flavs clock big, but on my dash.
so i guess my car is rice to ?
the only way i would use one of those things again is if i had a drag car that needed to rev up to 10k. </TD></TR></TABLE>
Mine only goes up to 8, cause I'm tasteful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">buy an si dash tippyman.</TD></TR></TABLE>
I don't wanna mess with that ****. Plus the stock one is always way off at higher RPM. I think I'm gonna just rip it out and put a shift light n the air vent though.
I got a SWP shift light/ digital tach i still haven't installed. I've seen em before tho, nice cause you can turn down or off the shift light and set the shift point without any ghey pills.
mike1114
Apr 19, 2006 06:39 PM
Mini-mEK4
Apr 29, 2004 07:29 AM
