what wire to tap into.. A/F guage?
alright i hooked up my a/f guage and tapped into the white wire in my primary o2 and it seems to work ok. But my friend told me u were supposed to hook it up to the green wire. so which one is it
Re: what wire to tap into.. A/F guage? (Mini-mEK4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mini-mEK4 »</TD></TR><TR><TD CLASS="quote">alright i hooked up my a/f guage and tapped into the white wire in my primary o2 and it seems to work ok. But my friend told me u were supposed to hook it up to the green wire. so which one is it</TD></TR></TABLE>
Your friends a moron, and your a bigger moron if you listen to him.
Re: what wire to tap into.. A/F guage? (Luserkid)
why the **** do u gotta flame u ****** i asked a simple question of what wire im supposed to splice into. dont post if your not gunna answer
You dumb ****, if you searched you would easily know its the white wire. Whats even more ******* retarded is that your dumb *** is on the right wire and it works FINE but your dumb *** friend thinks its the wrong wire. Maybe you should just tap into the green wire because thats probably the right wire. And then you come back and wonder why it doesnt work. ******* dumbass.
I had problems in the rain with Mine when I hooked it up to the o2 sensor. I ran it to I believe c16 on the ecu. It works much better now. Use a tap splice
SpeedMonkeyRacing
10-20-2004 01:33 PM
