Just changed my oil... but something weird happened...
Old Jul 31, 2007 | 07:48 PM
n77nxc's Avatar
Default Just changed my oil... but something weird happened...
I recently purcahsed a 2000 4 dr GSR that was theft recovery. I decided to change the oil tonight so I drove it up on those rhino ramps, went to the gym (1.5 hours) and came back to change the oil. I drained the oil from the oil pan and then started to unscrew the oil filter. To my amazement/concern, the filter had no oil in it. Nothing dripped out which it usually does on every other car I worked on. There was some residue of oil but not much. The inside of the filter did look used but I still can't get over why there's no oil in it.
Did this ever happen to anyone?
Edwin
Old Jul 31, 2007 | 07:50 PM
Kyle R's Avatar
Default Re: Just changed my oil... but something weird happened... (n77nxc)
Was it moist at all? Or just completely dry?
Old Jul 31, 2007 | 07:51 PM
honda1982's Avatar
That's weird!!! how does the used oil look??? maybe,maybe the oil pump is gone?
Old Jul 31, 2007 | 07:59 PM
n77nxc's Avatar
Default Re: Just changed my oil... but something weird happened... (herecomesboost)
It looked somewhat moist...it was like someone took a normal oil filter out and let it drain for an hour.
Oil pump... where's that? How do I make sure that's there? THe oil looked ok... nothing out of the ordinary. It was dark dark brown color
Thanks for the help
Edwin
Old Jul 31, 2007 | 08:03 PM
n77nxc's Avatar
UPDATE
Ok, I just went back and looked at the oil filter. I stuck my finger into it and touched the inside walls and it was semi-moist (slight residue of oil on my fingers). However, I started to shake the filter and oil started to slowly seep out. I can hear the oil inside the filter. Is this something I should be concerned about? Any ideas?
Edwin
Old Jul 31, 2007 | 08:11 PM
SlammedDC2teg's Avatar
What did the oil level look like before the oil change? If it was low then that could happen if you let it sit. Happend on my friends 2000 ls. If it didnt have oil circulating in it your car would be knocking and probably seize up.
Old Jul 31, 2007 | 08:15 PM
n77nxc's Avatar
Default Re: Just changed my oil... but something weird happened... (SlammedDC2teg)
The oil level was topped off a few days ago. I have driven the car to work this week (I bought it last sat). Should I be driving the car at all then?
Edwin
Old Jul 31, 2007 | 08:19 PM
bshshondaman06's Avatar
of you let the motor sit the oil will drain down to the oil pan and you can have a filter with out alot of oil.. i thought it would take longer then 1.5 hours
Old Jul 31, 2007 | 08:23 PM
Kyle R's Avatar
Default Re: (bshshondaman06)
Yeah, what did the oil look like when you drained it? I'm sure the oil pump is fine. If it wasn't pumping oil, the engine would have siezed.
Old Jul 31, 2007 | 08:25 PM
Uncle Willie's Avatar
Ur filter probably had a faulty anti-drain back valve. Not to big of a deal but whenever u start ur motor, ur pretty much dry starting it every time, unlike a primed filter where the oil is right their and pressure builds instantly.
Poke a hole in the top of the filter and more oil will drain out.
Dont worry, oil pump not shot IMO.
Old Jul 31, 2007 | 08:29 PM
Kyle R's Avatar
Default Re: (Uncle Willie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uncle Willie &raquo;</TD></TR><TR><TD CLASS="quote">Ur filter probably had a faulty anti-drain back valve. </TD></TR></TABLE>
I didn't even think of that.
Old Aug 1, 2007 | 05:46 AM
n77nxc's Avatar
Thanks for the info. I drove the car to work this morning (25 miles) and everything seemed fine. If there was something wrong with the pump, shouldn't my oil light come on? Also, IF my pump was bad, how long would it be before the motor seized up?
I plan on taking out the filter when I get home to see if oil drips out. Anyone have any other ideas or things I should do to make sure everything is functioning properly?
rayzian
16
Aug 17, 2007 06:48 AM
J.nguyen
Oct 14, 2006 06:04 AM
HondaEJ7
Feb 13, 2006 05:18 PM
Sohc Driver
Jul 14, 2003 02:10 PM
2005 TSX
Nov 4, 2002 08:41 PM
