my crx is idling at 3000 rpm with the check engine light on!!!!!!!!!!!!!
Old Jul 31, 2007 | 06:35 PM
Phrost's Avatar
Default my crx is idling at 3000 rpm with the check engine light on!!!!!!!!!!!!!
my crx is idling real high and when driving it kicks real hard and drops to 2000 rpm with the check engine light on and it sounds like it is missing lke bogging and then it takes off again and the ligt is still on and then when its in park it goes back up to 3000 rpm and the ligt turns off if you know anything about this and have answers it would be great if you let me know ive been having this problem for 2 weeks now and cant figure out what it is ................................
Old Jul 31, 2007 | 06:39 PM
beatthisspeed69's Avatar
wat code is it throwing
Old Jul 31, 2007 | 06:46 PM
Phrost's Avatar
Default Re: (beatthisspeed69)
i dont know yet im checking it right now will get back.......
Old Jul 31, 2007 | 06:48 PM
2slow4stock's Avatar
^^ what he said. What is the code.
What motor is it and did you swap.
Old Jul 31, 2007 | 07:04 PM
Phrost's Avatar
Default Re: (2slow4stock)
its a single zc and i checked the computer and its not throwing no codes and i run it on the freeway right now and its not doing it anymore ....heres a question i have a water problem there is alot of water on the floor board of the car it gets like that when ever it rains and theres no carpet and the computer and the harnesses get wet can the water cause the computer to trip ...and how can i get rid of the water is the dain ducts clogged in the sunroof or what....is it that or something else.....
Old Jul 31, 2007 | 09:00 PM
89s1's Avatar
Default Re: (Phrost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phrost &raquo;</TD></TR><TR><TD CLASS="quote">its a single zc and i checked the computer and its not throwing no codes and i run it on the freeway right now and its not doing it anymore ....heres a question i have a water problem there is alot of water on the floor board of the car it gets like that when ever it rains and theres no carpet and the computer and the harnesses get wet can the water cause the computer to trip ...and how can i get rid of the water is the dain ducts clogged in the sunroof or what....is it that or something else..... </TD></TR></TABLE>
wheres the shovel when you need it....
life&gt;you
I say go drop your cellphone in the toilet, and see if it "trips"
Old Jul 31, 2007 | 09:17 PM
Phrost's Avatar
Default Re: (89s1)
haha very funny smart boy get a life ******* it sounds like they put your head in a toilet a little too much buddy............................
Old Jul 31, 2007 | 09:19 PM
wiZCo's Avatar
Stouts 'n' Scotch
Seriously, get rid of the water problem, get a new ECU and see if it solves the problem. Electrical things don't mix with water.
I'll bet it's coming in from your door seals.
Old Jul 31, 2007 | 09:44 PM
89s1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phrost &raquo;</TD></TR><TR><TD CLASS="quote">haha very funny smart boy get a life ******* it sounds like they put your head in a toilet a little too much buddy............................</TD></TR></TABLE>
*slow clap*
I would have been super-helpful in spoon feeding you an answer to your question but you answered it yourself.
electrical stuff+rain=bad... heck, you even seemed to think so yourself.
now, what you could do instead of calling me names over the innerwebs is go out to your car and get your neighbor to spray it with the garden hose, to see where the water comes in (you might wanna disconnect the battery for this.)
Once you know where the leak is you can promtly fix it so no further damage occurs.
If I really needed to say all that though theres bigger problems here than your obvious elementary school drop out.
Old Aug 1, 2007 | 06:31 AM
Phrost's Avatar
Default Re: (89s1)
thanks evrybody im just here for second opinions man i had bad experiences in the past replacing everything i could think of and nothing when i finally got it fixed i had a empty pocket ...
MrLeon77
Dec 25, 2015 01:48 PM
blink_977
May 21, 2009 12:45 AM
a2nchinaman
14
Oct 8, 2007 09:41 AM
MinimalXistance
12
Apr 15, 2006 12:24 AM
CRX-stevie
Jun 1, 2002 10:01 PM
