help me out real quik?
Old Jul 31, 2007 | 03:01 PM
ekhatch978's Avatar
Default help me out real quik?
check out my thread in the hybrid section. please give me some input.
https://honda-tech.com/zerothread/2057667
Old Jul 31, 2007 | 03:08 PM
hatchling37's Avatar
Default Re: help me out real quik? (ekhatch978)
You said it doesn't blink... does it stay solid? If so, your ECU is **** housed.
Old Jul 31, 2007 | 03:12 PM
ekhatch978's Avatar
Default Re: help me out real quik? (hatchling37)
yea it stays solid. what do you mean by **** housed? its just a piece of **** or? i bought it off ebay LOL. its a p06 that was converted to manual and has a stock gsr basemap. the guy has a **** load of good feedback. should i just get a stock p72 and try it? this is a big dissapointment right now because ive beeen doing this all myself for like 2 months now, i just wantt o drive the damm thing. it does feel sick when i take off though, man im anxious
Old Jul 31, 2007 | 03:14 PM
That's what's known as code 0. Your ECU is done, sorry. You'll just have to go find a new one. Or talk to your seller and see if he/she can do anything to help you since they sold you a piece of ****. That sucks, good luck.
Old Jul 31, 2007 | 03:19 PM
ekhatch978's Avatar
damm the bastard sent me a new chip too but it sitll didnt fix the problem.
Old Jul 31, 2007 | 03:34 PM
ekhatch978's Avatar
hey but is the bad ecu causing my problem or is there still a problem with something else?
Old Jul 31, 2007 | 03:44 PM
Default Re: (ekhatch978)
You can't tell with the bad ECU. It will only tell you that itself is bad. It doesn't have the capacity to run other diagnostic scans.
Edit: didn't read your post thoroughly. A bad ECU will make it run like ***, so it's a majority, if not all of your problem.
Old Jul 31, 2007 | 03:49 PM
Bangher4$'s Avatar
Get a obd2 ecu, then get your codes. use the scantool
solid light could also mean, bad ecu ground, bad chip or bin.
Old Jul 31, 2007 | 03:53 PM
ekhatch978's Avatar
obd2 is just going to give even more codes. i did my whole swap for obd1 anyway and i dont want to go back and change things. i can still blink out the codes from the obd1 i just need a good ecu
EgSalad
Northeast (Sales)
103
Apr 29, 2008 10:51 AM
2.2 teg
Oct 25, 2005 01:45 AM
Da1spaz247
Jan 14, 2005 12:46 PM
white4drint
Mar 17, 2003 09:20 PM
ion_four
Oct 8, 2002 01:19 AM
