Cleaning pistons carbon buildup
Old Jul 30, 2007 | 05:15 PM
lude98SH's Avatar
Default Cleaning pistons carbon buildup
The pistons are in the block... ive been using brake clean, gum cutter, seafoam, carb cleaner and its working decent however there is still some carbon on the pistons, i dont want to destroy the deck however want these things cleaned as good as i can get them.
Old Jul 30, 2007 | 05:57 PM
street_ride14's Avatar
Default Re: Cleaning pistons carbon buildup (lude98SH)
They will still get dirty so don't try to polish them up
This is what worked for me ...>> Spray carb cleaner on a rag and scrub with lots of pressure from your hand. Grab a box cutter and carefully work away at the carbon build up that is toast onto the piston. This is what I did while my cylinder head was out and they came out great. Be patient, this method should take about 30 minutes per piston.
Old Jul 30, 2007 | 05:59 PM
SnlpeR's Avatar
i scraped on mine with a small flathead screwdriver
then used a rag with atf on the leftovers
92hondalude's Avatar
Default Re: (SnlpeR)
**** leave it on more compression!
Old Jul 30, 2007 | 06:08 PM
Eddiebx's Avatar
what i did was crank the engine to half dead center, is that even a term? haha, but basically so all the pistons are about even, then fill each bore up with ATF and let it soak until the atf eventually seeped through the rings, then did it again, it softened up the caked on carbon a good deal. then i went and cleaned them off with carb cleaner and seafoam or something, i forget. u can gtry soaking with seafoam instead as well, probably all the same!
Old Jul 30, 2007 | 07:31 PM
SnlpeR's Avatar
^^^ i tried doing that first
but the atf wouldnt seep down after 2 days of letting sit
so i had to scoop the damn atf out of the cyls
Old Jul 30, 2007 | 09:29 PM
mgags7's Avatar
lol^^
you could try a hard brush maybe even a wire brush or some sort of mild dremel attachment, just put the thing at tdc so you don't hit the cyl. wall
Old Jul 30, 2007 | 10:02 PM
InvaderTrax's Avatar
Mine all came off with some steel wool
Old Jul 30, 2007 | 10:49 PM
98vtec's Avatar
moderator emeritus
Default Re: (InvaderTrax)
dremel + polishing wheel
Old Jul 31, 2007 | 07:20 AM
NirVTEC's Avatar
Default Re: (92hondalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">**** leave it on more compression! </TD></TR></TABLE>
Old Jul 31, 2007 | 10:00 AM
97luder's Avatar
My first question is.....why do you need to clean it to the bare metal?
My second question is...why not just use sea foam/atf once every couple of weeks. it will eventually clean out the combustion chamber.
Lastly, you can clean it all you want, it's going to carbon up regardless. That's just the nature of the beast.
oh yeah, my vote goes to higher compression as well
-kl
Old Jul 31, 2007 | 12:50 PM
lude98SH's Avatar
Default Re: (97luder)
i just used steel wool and it got it to where its mostly all off on the head of the piston but i couldnt get all of the carbon out around the valve reliefs. I was alittle worried about hitting the deck because i believe the honda spec is .004 out and u should mill, it there anyway i can take material out with steel wool or would it have to be alittle more gritty like sandpaper or something to actually take material off the deck ?
dem0nk1d
May 22, 2012 10:00 PM
turbotime
Jun 21, 2006 06:56 PM
EK FLY
Jan 31, 2006 05:42 PM
hondaeg8
Jan 6, 2004 05:08 PM
KayOs
Oct 4, 2001 10:12 PM
