SEARCH is messed up. Need help with 3 bar Map Sensor
I have a 97 hatch and need to wire in a 3 bar with Piggy tail. Can anyone tell me the wire colors that match the piggy tail.
yellow/red stripe
green/ white stripe
white/ yellow stripe
yellow/red stripe
green/ white stripe
http://www.hondata.com/tech3barmap.html
unplug your map sensor and look inside the plug.There should be v o g over each pin but maybe not in that order.This is how my wiring went color wise but again it could be diffrent
voltage is V yellow red
signal is O white
ground is G green white
on the 3 bar
a is ground
b is signal
c is 5v (voltage)
Then go over all that with a volt meter.
signal is O white
on the 3 bar
a is ground
b is signal
c is 5v (voltage)
stpacura
Engine Management and Tuning
Aug 8, 2008 10:35 PM
