3 bar map sensor install
Old Jun 6, 2003 | 09:47 PM
R THIS's Avatar
Default 3 bar map sensor install
when you install a 3 bar map sensor, is it safe to tap into another vaccume line to get the pressure or do you need to tap the intake manifold and run a seperate line to the sensor???
Old Jun 6, 2003 | 11:26 PM
95c1v1cs1's Avatar
Default Re: 3 bar map sensor install (R THIS)
It fine to tap it pretty much anywhere on the Intake Manifold. Try to spread out your Vacumm sources tho.
Old Jun 8, 2003 | 10:49 AM
R THIS's Avatar
Default Re: 3 bar map sensor install (95c1v1cs1)
ok thanx
next question is.. with the 3 bar map how do i know what wire goes to which pin?
the map sensor says "C" "B" "A" on it near each pin
the wires going to my stock map sensor are red/green, green/white, and yellow/red
Old Jun 8, 2003 | 12:31 PM
95c1v1cs1's Avatar
go here.... http://www.hondata.com/3barinstall.html
Next time here... https://honda-tech.com/zerosearch
Old Jun 8, 2003 | 03:45 PM
R THIS's Avatar
thats for obd1 cars
mine is obd2
for obd1 ground =green/white
map signal = white
5 volt = yellow/red
obd2 ground = green/white ??
map signal = red/green ??
5 volt = yellow/red ??
is that correct??
BTW i did a search and found nothing that answered my question!!
Old Jun 8, 2003 | 09:24 PM
pissedoffsol's Avatar
25 Year Member
consult your helms manual...
http://www.helminc.com
Old Apr 6, 2008 | 11:35 AM
thegatekeeper14's Avatar
Default Re: 3 bar map sensor install (pissedoffsol)
map signal = white
5 volt = yellow/red
^ those are the colors that are on my 3bar map sensor
red
green yellow
2 black yellow
green
what goes were guys?
Old Apr 7, 2008 | 10:59 AM
Sprockets's Avatar
Several companies make them, but this is the best way to provide vacuum for your map sensor:
https://honda-tech.com/zerothread/2258115
Old May 2, 2008 | 12:55 PM
sfgreddiedsi's Avatar
thanks for the info!
I B BANGGIN
Feb 6, 2007 07:50 PM
prelude1911
Nov 24, 2005 04:05 PM
scUba-stEve
Aug 26, 2005 12:14 PM
paul93sir
May 31, 2005 03:53 PM
