problems with the idel
Old Jul 30, 2007 | 03:45 PM
bardeal2's Avatar
Default problems with the idel
ok i just put in a zc motor and i am having trouble with the idel the cable is right lose and the idel is at almost 2000 and with it been driving for awile the rpm keeps on going up and down like a yoyo when i am at idel if some can let me know what it could be it will be alot of help thanks
Old Jul 30, 2007 | 03:56 PM
SIred91's Avatar
Rainman
Default Re: problems with the idel (bardeal2)
Whats an idel..???
Old Jul 30, 2007 | 03:58 PM
wiZCo's Avatar
Stouts 'n' Scotch
Are you saying the throttle cable is loose?
You either hooked up the vaccuum lines incorrectly, your idle is set too high, the throttle cable is too tight or the IACV is dirty / malfunctioning.
Old Jul 30, 2007 | 04:04 PM
garageEF's Avatar
Default Re: problems with the idel (wiZCo)
also...did you fill and bleed the coolant system correctly?...air bubbles in the system confuse the iacv and cause the idle to fluctuate. your throttle cable is more than likely too tight, loosen it all the way, then start the car...see if it still idles high.
Old Jul 30, 2007 | 04:05 PM
bardeal2's Avatar
Default Re: problems with the idel (garageEF)
yea the cable it right lose
Old Jul 30, 2007 | 04:06 PM
bardeal2's Avatar
is the iacv the same as the one on my old 1.5 if it is i will switch it cause i know that one works good still
Old Jul 30, 2007 | 04:07 PM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bardeal2 &raquo;</TD></TR><TR><TD CLASS="quote">yea the cable it right lose
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bardeal2 &raquo;</TD></TR><TR><TD CLASS="quote">is the iacv the same as the one on my old 1.5 if it is i will switch it cause i know that one works good still</TD></TR></TABLE>
No.
Old Jul 30, 2007 | 04:09 PM
SIred91's Avatar
Rainman
WTF.....wurr you frum boy?
Old Jul 30, 2007 | 04:14 PM
bardeal2's Avatar
Default Re: problems with the idel (SIred91)
i dont know first honda motor swap i ever did and my idel is all screwed up and i am trying to fix it i thight i did pretty good so far if thats the only problem i got since i did alot of wirerings
Old Jul 30, 2007 | 04:41 PM
abnaasefmb's Avatar
tps, timing too
Old Jul 30, 2007 | 04:51 PM
bardeal2's Avatar
Default Re: problems with the idel (abnaasefmb)
well i did had to do a timming belt on it cause the old one was starting to rip apart
bk7794
13
Jun 21, 2012 08:17 PM
1baddturbosi
Aug 9, 2007 08:12 PM
bseries_beast
Jul 2, 2004 09:25 PM
crazy eyez killa
Mar 3, 2004 01:11 PM
LillDragun
May 3, 2002 03:00 AM
