wiring a non vtec to a vtec?
anyone know a site or info on wiring a 95 integra ls with its wiring harness to a b16a sec gen. what im really asking for is a way to wire a non vtec to a vtec useing the same wiring harness. i know more wires are needed but where?
Pin A4 on the ECU harness is for the VTEC solenoid. If you are running an ECU that still requires a VTEC Oil Pressure Sensor input, pin D6 is for the signal side of the sensor, and the ground goes to ground [duh].
http://www.superhonda.com/foru...17405
^ That's the link that gave me the info on pinning out my VTEC swap.
For the VTEC Oil Pressure Sensor?
I'm not sure what color the wires are on your sender, but on my B16 head [USDM] the blue [had a stripe, can't recall offhand what color it is] wire goes to pin D6 on the ECU, and the brown wire [also striped I think, can't remember color either] goes to ground. Put it on a solid chassis ground, or the battery negative terminal for best results.
quicksol95
Mar 19, 2004 01:50 PM
AngelTeg
Aug 24, 2003 07:03 PM
