boost dropping in high rpm???
i am having a problem.
While tuning, found out that the boost dropps in high rpm around 7500 rpm.
Was running about 18~20 psi then dropps to 10psi in 7500 rpm.
any idea why??
any idea why??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96vtecI4 »</TD></TR><TR><TD CLASS="quote">Turbo's to small.</TD></TR></TABLE>
exactly what im thinking... What size is the turbo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herecomesboost »</TD></TR><TR><TD CLASS="quote">Sounds like your turbo has asthma
lol
</TD></TR></TABLE>lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">what are you using for boost control?</TD></TR></TABLE>
okay here is more info on my set up.
Sleeved GSR motor
GT30R (too small for y'all?? lol)
As far as the boost controller, i am just using cheap manual boost controller
with ball and spring u know..
Redline set at 8400rpm
I was thinking about the WG spring issue,
It was reading 10psi so i am assuming .7bar or soemthing?
I boosted it up to 18psi and i was it dropping it to around 10 or 11psi.
Any other thoughts??
Sleeved GSR motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eh3si »</TD></TR><TR><TD CLASS="quote">okay here is more info on my set up.
Sleeved GSR motor
saw a similar problem on my friends car with a gt30r, but not as bad. boost was set for 21psi, but dropped off to 16psi by redline at the track. put a bigger spring(13psi) and it helped a ton, only dropped 1-2psi at the top end.
Sleeved GSR motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importsautomotive »</TD></TR><TR><TD CLASS="quote">what kind of blow off valve </TD></TR></TABLE>
Turbo Xs RFL
Turbo Xs RFL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by full Circling »</TD></TR><TR><TD CLASS="quote">and make me a sandwich. pb&j.</TD></TR></TABLE>
damn that sounds good right now(i appologize for the no tech)
its your boost controller....when at low rpm you will see 18psi becuz theres not that much pressure to your boost controller. when you reach high rpm.. so many pressure is built so there going to push down on your boost controller like crazy this is wat causing your boost to drop down.to is wastgate spring or almost to it....i have same problem change to electronic and solve my problem..........
Yes, i had teh same problem with my levels of boost towards redline and it would cause the pressure to fluctuate a lot. I went with a stiffer spring and all my problems were solved. I was using the Apexi AVC-R and that couldnt even compensate for all the added pressure at higher RPMs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">something is wrong
when running a small turbo. the boost may taper and drap a few psi by redline
but there no way you should be going from 18 psi to 10psi </TD></TR></TABLE>
volkswagon 1.8T motors do it all the time.
if you are pushing the boost controller to make too much boost over the spring thiss could happen.
Which one will be more dangerous for stock internals? small turbo high psi / big turbo low psi? or h
elpiar
Aug 4, 2005 01:52 PM
-iLLuZioN-B18C1
Feb 20, 2004 07:24 AM
