fuel leak ?
Old Jul 29, 2007 | 04:10 PM
hondachris1994's Avatar
Default fuel leak ?
I have a small fuel leak at the fuel filter, the leak is rt under the fuel line that goes to the fuel rail, its leaking rt on the fuel filter, I took it off and there are 2 washers 1 for the top and 1 for the bottom. What can I do to fix =the leak, I have takwen it off several times and put it back together but still no luck...any help is appreciated
Old Jul 29, 2007 | 04:14 PM
hondamark35's Avatar
Default Re: fuel leak ? (hondachris1994)
you need to replace these two washers and make sure that no particles of dirt or anything gets on them or the line when you install the new ones.
these are crush washers and usually do fine if you reuse them, but when they start to leak like with your's, it's time for new ones. you'll likely have to get them from honda to be sure they fit right, but if you have a good auto supply store nearby they may have aluminum crush washers that will fit for a lower price.
Old Jul 30, 2007 | 12:06 PM
thanx man,I kinda thought it was the washer but I wasnt 100 percent sure, I was gonna try to silicone it but that sounds kinda ghetto, but ima try the autoparts store and see if they carry those washers, if not ill go to the dealer
EFin' Kyle
Apr 27, 2006 11:43 PM
EK FLY
Jan 6, 2006 05:04 PM
bikeboy80
Oct 14, 2002 03:51 PM
schwett
Aug 30, 2001 03:28 PM
