D15B swap into 93 SI..shifting problem..
Old Jul 28, 2007 | 06:30 PM
Manolo's Avatar
Default D15B swap into 93 SI..shifting problem..
like the title says, i did the swap into my hatch. the ONLY problem im having is that shifting into first and second is hard..i have to force it in..what could the problem be?? shift linkage??
Old Jul 28, 2007 | 06:55 PM
97Ej6mike's Avatar
Does it make any grinding noises, or are you just having a hard time? It has little to do with what motor you have, as much as it does the condition of your tran's, clutch assembly, and master/slave cylinder. Could be that your linkage is hitting something, like your exhaust, or you tightended the 10mm bolt on the linkage too much.
Old Jul 28, 2007 | 07:23 PM
Manolo's Avatar
Default Re: (97Ej6mike)
everything is new, clutch, etc..my dad said it was the shift linkage also..
Old Jul 28, 2007 | 08:10 PM
Mista Bone's Avatar
D Tranny Guru
only 1-2?
How is down shifting from 3-2?
Did you reuse your Si tranny or the one that came with the swap?
I'm going with a broken 1-2 shifter fork in the tranny take came with the swap as a educated guess for now.
Old Jul 30, 2007 | 06:03 PM
Manolo's Avatar
Default Re: (Mista Bone)
i used the tranny that came with the swap..its only 1-2..downshifting goes in smooth though..and if i play with first and second going up and down it shifts smoothly, but thats doing that while standing.
Old Jul 31, 2007 | 12:27 AM
Mista Bone's Avatar
D Tranny Guru
sounds like a broken 1-2 shifter fork.....or CS bearing has walked out of the case.....
https://honda-tech.com/zerothread?id=2051578
H2BSTUPID
Transmission & Drivetrain
Mar 24, 2009 11:07 AM
beginmyhonda
Jan 16, 2009 07:32 AM
jvaughn
26
Mar 16, 2008 06:25 PM
sic95av6
Jun 28, 2004 03:56 PM
IN2VTEC
Nov 18, 2002 09:35 PM
