B18c1 turbo a/r 0.63 or a/r 0.82 hotside
Old Jul 28, 2007 | 01:58 PM
christion's Avatar
Default B18c1 turbo a/r 0.63 or a/r 0.82 hotside
Hi, I have a crx with a b18c1 turbo. It's a fully built motor and wanted to achieve
425 whp. I have a sc61 turbo with 2 different housing. Which one is better with better spool without affecting the 425 whp? I am asking because I have a friend with the same kind of car and setup, but he is using the a/r 0.82. He is using the long geared ratio cable tranny y21 and it seems when he throws the 3rd gear, the rpm goes a little bit below 6000 rpm and it takes a while to get back to 8500 rpm.
He has about 380 whp and 15 psi. Any suggestions??
Old Jul 28, 2007 | 02:13 PM
1Quikgsr's Avatar
the .63 will spool quiker the .82 will give you bigger top end.
Old Jul 28, 2007 | 02:18 PM
turboedc2's Avatar
Default Re: B18c1 turbo a/r 0.63 or a/r 0.82 hotside (christion)
.82
Old Jul 28, 2007 | 02:40 PM
Kyle R's Avatar
Default Re: B18c1 turbo a/r 0.63 or a/r 0.82 hotside (turboedc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboedc2 &raquo;</TD></TR><TR><TD CLASS="quote">.82</TD></TR></TABLE>
Old Jul 28, 2007 | 03:57 PM
christion's Avatar
Default Re: (1Quikgsr)
That means that I'll have less MPH with the 0.63??
Old Jul 28, 2007 | 04:02 PM
1Quikgsr's Avatar
Default Re: (christion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by christion &raquo;</TD></TR><TR><TD CLASS="quote">That means that I'll have less MPH with the 0.63??</TD></TR></TABLE>
well if 425whp is all your looking for and the turbo that spools the fastest your choice would be the .63
Old Jul 28, 2007 | 04:44 PM
tegdude227's Avatar
is the 82 only good for high revving of a vtec motor or would it suit the ls motor to ?
Old Jul 28, 2007 | 05:25 PM
needmypass's Avatar
Default Re: (tegdude227)
lol on a ls man that would suck
Old Jul 28, 2007 | 05:38 PM
quicksilver1689's Avatar
i ♥ snails
you wouldn't flow enough air and with a long geared tranny it wouldn't stay in the power band long enough to be efficient
Old Jul 28, 2007 | 07:47 PM
Kyle R's Avatar
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegdude227 &raquo;</TD></TR><TR><TD CLASS="quote">is the 82 only good for high revving of a vtec motor or would it suit the ls motor to ?</TD></TR></TABLE>
Yes, unless you like a very narrow powerband
Old Jul 28, 2007 | 09:59 PM
bigbadboy's Avatar
i would go with the .63 i had one on my GSR making 500 to 9.5 and i had a very very nice powerband with no boost dropping off. this was on a GT3040R
Old Jul 28, 2007 | 11:21 PM
GetawayInMoscow's Avatar
Default Re: (bigbadboy)
.82 a/r
thegeezerkid
Jun 14, 2008 10:56 PM
jdmcivicsi7
Feb 9, 2008 08:28 AM
Topdawgg
Jan 23, 2006 06:54 PM
turbochargeb18c
Aug 5, 2005 10:11 AM
jgcrxsi
24
Feb 11, 2004 11:46 PM
