no jumper to read ecu codes? (pix!)
Old Jul 28, 2007 | 01:05 PM
Aralliius's Avatar
Default no jumper to read ecu codes? (pix!)
ok so i have been look for my jumper cable for my ecu to read what code i am throwing and i cant seem to find it here are some pix wtf and i missing?
srry for size!
n ow is it not thair or am i blind?
Old Jul 28, 2007 | 01:11 PM
hondamark35's Avatar
Default Re: no jumper to read ecu codes? (Aralliius)
check behind that ecu, sometimes they get caught behind it.
i'm sure it's there, just keep fumbling around till you find it.
Old Jul 28, 2007 | 03:48 PM
Aralliius's Avatar
Default Re: no jumper to read ecu codes? (hondamark35)
ok hondamark35 i took your advise and look what i found! nothing lol i took a pic
agin srry for size!
Old Jul 28, 2007 | 03:54 PM
egsleepercivic's Avatar
its in that group of wires thats going up under the dash, not the ones that plug into ecu it probably just pushed up there
gl
Old Jul 28, 2007 | 03:59 PM
Aralliius's Avatar
Default Re: (egsleepercivic)
u mean like in that black thing?
Old Jul 28, 2007 | 04:02 PM
no the group of wires where the dash and glove box come together
Old Jul 28, 2007 | 04:04 PM
Aralliius's Avatar
lol ok but thair is another angle of that spot in my first post but ill go loook when it stops raining and let yall know
Old Jul 28, 2007 | 04:05 PM
gsrhatch2356's Avatar
you see that brown and black wire in the pic. follow that to your connector to jumper. if that dosent work then let me know and I will post pin outs on the ecu when I get back to work and you can jumper it there and still get codes.
Old Jul 28, 2007 | 04:07 PM
Aralliius's Avatar
Default Re: no jumper to read ecu codes? (gsrhatch2356)
ok will do! thanks!
if you look at your first pic I believe its the wires with the green sheath on them, let us know when you find them
Old Jul 28, 2007 | 05:53 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">if you look at your first pic I believe its the wires with the green sheath on them, let us know when you find them</TD></TR></TABLE>
X2.
Here is a link with a pic:
http://www.geocities.com/ng_ra...s.jpg
Old Jul 28, 2007 | 05:58 PM
Aralliius's Avatar
Default Re: (tech8)
lol damn i feel dumb that was it i gess i just didnt want to pull on sumthing i would break but anyway ill check and c what code i throwing and get to fixing lol
Old Jul 29, 2007 | 12:44 PM
Aralliius's Avatar
Default Re: (Aralliius)
ok so i found it and jumped it and i got 19 out of it, which stands for Automatic transmission lockup control valve WTF is that!! LOL!!
Old Jul 30, 2007 | 10:33 AM
Aralliius's Avatar
bump!
Old Jul 30, 2007 | 05:50 PM
Aralliius's Avatar
bump!
Old Jul 30, 2007 | 06:04 PM
do you have an automatic if so I believe it's a solenoid/valve on the auto trans, if not get a manual ecu
Old Jul 30, 2007 | 06:15 PM
Aralliius's Avatar
ok then! thanks man junk yard here i come lol
ej8ster96
May 20, 2010 09:45 AM
gmoneyef
Oct 28, 2006 06:11 PM
ludatic
Nov 2, 2003 10:46 PM
