need sugesstion for turbo cams.....
Did some searching but didn't find much usefull info, so I need help. I was wondering how good or bad are N/A cam for turbo. The deal is that I want to run N/A for a little bit until I can afford my turbo setup, silver surfer it is. compression is nearly 10.5:1.
another question, is there any difference from CTR to ITR cams? which is better for NA?
Otherwise what cams do you guys most preferred?
The car is going to be a sleeper so, it's not going to be out that much. LSVTEC with forged internals.
equal length is what I have in mind. don't have any of the listed cams yet. are skunk2 pro2 better than skunk2 pro1? I've heard of some people putting the pro2s down below the type R cams but I don't know much about cams. So the way I see it is all motor cams are also good for turbo application as long as you use equal leng manifold for the turbo setup, right? is there quite a bit of difference in the CTR and ITR cams?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">00-01 usdm itr and ctr cams are indentical</TD></TR></TABLE>
fixed
STOCK CTR CAMS
Duration Duration @ .050 Gross Lift w/ 1.55
294 / 305 240 / 232 447 / 416 Identical to 00-01 ITR cams
294 / 286 233 / 224 449 / 417 Identical 97-99 except that CTR has 3* more duration on intake than ITR
fixed
STOCK CTR CAMS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4max »</TD></TR><TR><TD CLASS="quote">I've heard of some people putting the pro2s down below the type R cams</TD></TR></TABLE>
Haha, that's rich.
Last Pro2 NA car I saw made 258 whp and probably had a bit more left in it. You won't do that on factory cams, but the JDM-loving *********** will say anything to edit history so Hype-R is better than anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4max »</TD></TR><TR><TD CLASS="quote">So the way I see it is all motor cams are also good for turbo application as long as you use equal leng manifold for the turbo setup, right?</TD></TR></TABLE>
Equal length is irrelevant.
The way it always works is the people looking for NA gains now and boost later rarely build a correct NA or a correct boosted vehicle, but waste all sorts of money on **** that isn't ideal for either setup. Why not just do it once, and do it right?
Haha, that's rich.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis »</TD></TR><TR><TD CLASS="quote">
Haha, that's rich.
The way it always works is the people looking for NA gains now and boost later rarely build a correct NA or a correct boosted vehicle, but waste all sorts of money on **** that isn't ideal for either setup. Why not just do it once, and do it right?</TD></TR></TABLE>
haha in other words learn to build and then learn to tune it correctly
Haha, that's rich.
understood
understood
