ecu help
Old Jul 27, 2007 | 01:38 PM
CeeJayy's Avatar
Default ecu help
so i converted my car to obd1 with a obd 2 to obd1 conversion harness.. my friend and i tried to scan the ecu for codes with a scanner but it will not pick up codes off the obd 1 ecu. its like it gets lost in the harness.. before we could get the codes out of the obd2 ecu with no problem.. and one have any ideas on how to just directly access the obd1 ecu??
Old Jul 27, 2007 | 02:46 PM
perseverance's Avatar
there's no jumper plug in ur car? if so, jump the plug and count how many times ur check engine light comes on
slowcivic2k's Avatar
Default Re: ecu help (CeeJayy)
Use a paperclip and jump the SCS connector. An OBD2 scan tool will not properly stream data from an OBD1 ECU.
Old Jul 27, 2007 | 02:48 PM
CeeJayy's Avatar
Default Re: ecu help (slowcivic2k)
the scan tool is universal for numerous cars. my buddy works at an engine shop... we already used a paper clip and it did not blink at all
Modified by CeeJayy at 4:00 PM 7/27/2007
Old Jul 27, 2007 | 02:57 PM
tha_badguy's Avatar
try using wire
its easier
Old Jul 27, 2007 | 03:49 PM
EM1_00Si's Avatar
Default Re: (tha_badguy)
maybes theres no codes to be found?
Old Jul 27, 2007 | 07:48 PM
forcefedferio's Avatar
Default Re: (EM1_00Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_00Si &raquo;</TD></TR><TR><TD CLASS="quote">maybes theres no codes to be found?</TD></TR></TABLE>
x2 haha
E.
Apr 21, 2008 08:40 AM
big-cat
26
Oct 19, 2006 11:14 AM
SCsol
Oct 7, 2005 05:35 AM
Jbunn2001
Jul 26, 2005 07:31 PM
C_I_V_I_C
Nov 5, 2003 05:26 PM
