ecu question
would there be any problem if i step down my 2000 integra to obd1 by just using the step down harness and an obd1 p72 is theres anything else i have to do so it dont mess up the ecu
An obd2 to obd1 jumper harness is a plug & play harness which will allow you to run an obd1 ecu. Running an obd1 ecu has it's advantages as you can chip the ecu and run custom programs which can allow you to properly tune a vehicle.
For more information read over http://www.phearable.net/tech/....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">An obd2 to obd1 jumper harness is a plug & play harness which will allow you to run an obd1 ecu. Running an obd1 ecu has it's advantages as you can chip the ecu and run custom programs which can allow you to properly tune a vehicle.
You can get a harness for $75.00
http://jdmshit.com/ecu/index.html
