water temp gauge
Old Jul 26, 2007 | 08:39 PM
powerdbygarrett's Avatar
Default water temp gauge
i just got my self a autometer water temp gauge and wanted to know where everyone connects the sensor to? thanks
Old Jul 26, 2007 | 09:16 PM
Hawkze_2.3's Avatar
Default Re: water temp gauge (powerdbygarrett)
I took my stock sender out and screwed the gauge sender into the same place.
Old Jul 27, 2007 | 07:14 AM
dam man your just helping me out with everything. i apriciate that (sp?) but where is the stock sender located?
Old Jul 27, 2007 | 07:58 AM
Hawkze_2.3's Avatar
Default Re: (powerdbygarrett)
Glad to be of help, it's right under the distributor on the head:
Old Jul 27, 2007 | 10:39 AM
Mikey3000's Avatar
Default Re: (Hawkze_2.3)
i don't think autometer's sender fits there, unless they've changed it since i last had one. when i had one i just tapped the sending wire to the gauge to the 1-wire sending unit in the side of the head.
Old Oct 15, 2007 | 12:11 PM
Honda_Fanatic's Avatar
could you just splice into the stock sensor?
Old Oct 15, 2007 | 12:30 PM
boostedh22lude1's Avatar
Default Re: water temp gauge (Honda_Fanatic)
you have to get a t fitting and use both if you dont use the stock, ur fans wont come on.
Old Oct 15, 2007 | 04:55 PM
Default Re: water temp gauge (boostedh22lude1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22lude1 &raquo;</TD></TR><TR><TD CLASS="quote">you have to get a t fitting and use both if you dont use the stock, ur fans wont come on.</TD></TR></TABLE>
What kind of T-fitting?
alexb16hb
Jul 5, 2006 08:05 PM
Green Lude 93
Apr 21, 2006 07:53 PM
TypeR15
Feb 24, 2004 12:29 PM
speedymon
Apr 30, 2002 11:32 PM
