h22 swap in my EK
Old Jul 26, 2007 | 05:48 PM
whiteymo's Avatar
Default h22 swap in my EK
I just got my h22 swap done. The car ran great for about a month. Then the the vtec quit working. I have done all the test to check the wiring and make sure that was ok. It all checked out fine, and I have good oil press. Just wondering if you guys had an ideas. Thanks
Old Jul 26, 2007 | 05:49 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: h22 swap in my EK (whiteymo)
Any CEL's?
Your tach or speedometer stop working?
Old Jul 26, 2007 | 08:53 PM
qkcivic's Avatar
take you your vtec selonid off and clean it out inside some times they get built up with dirt and get blocked off
Old Jul 26, 2007 | 09:55 PM
teknoracing's Avatar
Default Re: h22 swap in my EK (qkcivic)
Solenoid.
Did it go out all of a sudden or did it sort of slowly get there.
Old Jul 27, 2007 | 02:48 AM
whiteymo's Avatar
Yeah the speedo quit working. It would sometimes work and then in the next gear it wouldnt then it just went out and went into to safe mode. Already cleaned the screen. Only CEL is for evap and EGR that where there to start with, No vtec CEL. Thanks for the help.
Old Jul 27, 2007 | 05:32 AM
bassysingh's Avatar
Your vtec wont work if your speedo is out. Get the clock fixed then see what happens, most likely you'll be fine after that.
Old Jul 27, 2007 | 05:45 AM
97Ej6mike's Avatar
VTEC will not engage if your speedometer is not reading.
Fix that, and your problems will be solved
Old Jul 27, 2007 | 08:38 PM
whiteymo's Avatar
thanks guy I will try that tomorrow.
poisonousbeef
Nov 3, 2007 01:21 PM
11secEk
Mar 11, 2006 07:49 PM
mkim12180
Apr 8, 2004 08:30 PM
COMplex.
Jul 17, 2003 05:51 PM
civicsitek GanGsTa
Oct 4, 2002 06:36 PM
