AVCR wiring help - RPM or Injector signal?
Old Jul 26, 2007 | 01:59 PM
RTW DC2R's Avatar
Default AVCR wiring help - RPM or Injector signal?
Ive searched around the net and on HT, unable to verify what I need to do.
Using a P28, need to tap into the RPM or Injector signal. The instructions state ..."the purple wire should be connected to the RPM signal. However, if you would like to monitor Injector signal, connect this wire to the injector signal."
First off, I dont see "RPM" or "Injector signal" in the P28 pin out. The closest I found to "RPM" is pin A21 for "Ignition Power Source" as found on the phearable.net website, which I assume is essentially the igniter?. And for "Injector signal", the pin out diagram shows each injector with its own pin out. Since it only has one purple wire to splice into the harness, I assume it wants to use A21 for Ignition Power Source rather than each individual injector??
Any help is appreciated.
Old Jul 26, 2007 | 02:06 PM
Turbo-charged's Avatar
Default Re: AVCR wiring help - RPM or Injector signal? (RTW DC2R)
use RPM.
AEM has really good wiring diagrams for these cars, but it still doesnt tell you "rpm"
if you want something where you dont have to think or figure it out, go to apexi's websight and download the manual for an SAFC/VAFC....that will tell you "rpm" signal for this vehicle.
Old Jul 26, 2007 | 04:17 PM
Blown90hatcH's Avatar
Tap it into the A21 position on the OBD1 setup.
/Done
Old Jul 26, 2007 | 04:53 PM
ladysman's Avatar
Default Re: AVCR wiring help - RPM or Injector signal? (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Tap it into the A21 position on the OBD1 setup.
/Done</TD></TR></TABLE>
Do not use the injector signal. Blown beat me to it.
Old Jul 26, 2007 | 05:48 PM
RTW DC2R's Avatar
thanks
Old Jul 26, 2007 | 07:38 PM
red02s2k's Avatar
have fun with tuning that damn thing...
Old Jun 22, 2008 | 10:54 AM
rdssk8rcs1's Avatar
Im having the same issue as this guy.
Would hooking it up as stated above allow me to monitor injector duty cycle?
Old Jun 22, 2008 | 02:44 PM
SovXietday's Avatar
Default Re: (red02s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red02s2k &raquo;</TD></TR><TR><TD CLASS="quote">have fun with tuning that damn thing... </TD></TR></TABLE>
It's not that bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdssk8rcs1 &raquo;</TD></TR><TR><TD CLASS="quote">Im having the same issue as this guy.
Would hooking it up as stated above allow me to monitor injector duty cycle?</TD></TR></TABLE>
No, you will just have RPM. Use your EMS to deal with duty cycle.
92civtegra
Jun 30, 2010 07:09 PM
hyper em1
Jan 31, 2007 09:46 PM
RTW DC2R
Dec 16, 2006 04:16 PM
TurboDC4
Mar 19, 2003 07:51 AM
