will my turbo make 400-450whp?
Old Jul 25, 2007 | 08:00 PM
teddy_dc2's Avatar
Default will my turbo make 400-450whp?
aiming for 400-450whp, i have a standard turbonetics t3/t04e .57 trim, .50/.63; or should i upgrade to something bigger? it's going on a bottom build b18c1. what is the max hp/psi for this turbo?
Old Jul 25, 2007 | 08:07 PM
1Quikgsr's Avatar
shouldnt be a problem for 400whp
Old Jul 25, 2007 | 08:21 PM
teddy_dc2's Avatar
i want to push it a little and try to squeeze 450... at about how much boost?
Old Jul 25, 2007 | 08:22 PM
qfast817's Avatar
Default Re: (teddy_dc2)
my friend made 408@17psi stock gsr with sk2 im
Old Jul 25, 2007 | 08:30 PM
teddy_dc2's Avatar
i hope eagle h beams and forged pistons do the trick. thanks for the info... 18-20psi is what i was thinkin... too.
Old Jul 25, 2007 | 09:13 PM
Schister66's Avatar
Man U FTW
it depends on the efficiency of the setup and when your fuel limits you, but yes the turbo is physically capable of making 450whp
Old Jul 25, 2007 | 09:19 PM
red02s2k's Avatar
what waste gate are you running to small of a spring can give you problems
Old Jul 25, 2007 | 10:28 PM
TheShodan's Avatar
Moderator
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">it depends on the efficiency of the setup and when your fuel limits you, but yes the turbo is physically capable of making 450whp</TD></TR></TABLE>
at over 22psi. That exhaust wheel is stressed for sure with that turbo, and IATs, will increase dramatically.
Old Jul 26, 2007 | 06:26 AM
PrecisionH23a's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
at over 22psi. That exhaust wheel is stressed for sure with that turbo, and IATs, will increase dramatically.</TD></TR></TABLE>
Bingo. I would upgrade to a larger turbo for 450whp.
Old Jul 26, 2007 | 11:37 AM
TunerToys's Avatar
Default Re: will my turbo make 400-450whp? (teddy_dc2)
I agree with a bigger turbo for your 450 goal.
That said, I'll throw in this idea. SInce you already own the 57Trim, and it will get you to 400hp, why not go ahead and use it to get your project started? That way you can build and tune the entire system, and get some real world performance numbers from it, using what you already have. This will allow you to find any issues with the system. Bottlenecks from routing, pipe sizing, intercooler flow, can all be found using the turbo you already own. Once those are found and corrected, and you approach the limits of the 57trim, then upgrade to the larger turbo.
My reasoning for this is based on the assumption that your 57trim is a standard Garret turbo, and that you can you will upgrade to the a larger Garrett turbo, which can support the 450HP level. Potentially, these two turbos will have the same configuration of all of the attachment points, allowing you to just bolt the new turbo into the existing system, without needing to modify the system.
Just a retune, and you're good.
Hope that helps.
Craig
Old Jul 26, 2007 | 03:50 PM
teddy_dc2's Avatar
yeah it's a standard bearing turbo... i can make this kinda power with my d-series with less money on the build.... i want to do an expensive build and aim higher but don't have that kinda money anymore. i wanna redo the setup but already spent too much on it. sellin loses value and most people would love what i have already... awh, what a mess...
400whp or 600+whp sleeved? i'll think about it..
IGotVTECyo
Feb 12, 2008 08:44 PM
CustomX113
Nov 20, 2006 09:27 AM
mrx
Oct 15, 2005 08:32 PM
civiceg500
Jul 21, 2004 05:10 PM
AsianMullet
Oct 25, 2003 11:56 AM
