2000 b18b into 92 teg
Old Jul 23, 2007 | 08:06 PM
dark_samurai73's Avatar
Default 2000 b18b into 92 teg
im posting this for a friend of mine, he wrecked his 2000 then blew his b18a in his 92, hes wanting to swap the b18b into it an isnt sure what all he needs, other than the obd2 to obd1 (i believe) harness what else will he need? searched an found nothing answering this question. thanks in advance
Old Jul 23, 2007 | 08:38 PM
Default Re: 2000 b18b into 92 teg (dark_samurai73)
anybody?
Old Jul 24, 2007 | 07:43 AM
hes got a complete engine/tranny out of his 2000, all i know that he needs now is the obd converter, hes saying his 2000 has wires going to weird places and because im deployed in iraq i am unable to help him more, he doesnt have an account on here so he asked me to get info, from the way he described the extra wires it sounds like a map sensor (maf, iat, ect). i could really use some input, do i have the obd codes wrong? any help would be greatly appreciated
Old Jul 24, 2007 | 09:09 AM
super jdm yo's Avatar
your best bet would be to reuse your headers and intake manifold assemby because it'll match up with your wiring already. then you're going to need a jumper for the ovd2 to obd1 or just keep it obd1 for tuning purposes.
oh yeah your going to need to keep the cable transmission unless you want to go out and buy the conversion for the hydro. but the motor was just blown, not the tranny, so just reuse it.
there's probably a lot of stuff i left out, but you're going to have to reuse a lot of stuff off the blown motor to make it easier. good luck
Old Jul 24, 2007 | 09:18 AM
Default Re: 2000 b18b into 92 teg (super jdm yo)
thanks alot, so if he uses the 92s header an intke manifold he wont need he obd convrter? and thanks for the tranny info ill let him know. if you have any other tips id greatly appreciate it, id have it done already if i were there, because id be able to see what needs to be done.
Old Jul 26, 2007 | 07:40 PM
ok, my moron friend tells me last night its a 91 not a 92, that changes some **** right? if recall correctly i read that the 91 was obd0, is that right?
Old Jul 26, 2007 | 08:50 PM
TsujenDB1's Avatar
90-91 odb0 yeah. But you can still get the harness
Old Jul 26, 2007 | 08:56 PM
Emg's Avatar
Emg
Well you could always use the obdo wiring and just change all sensors over to the other motor. Its not that hard also reuse the computer and dizzy of the 91.
AdrenalineAngel
Oct 27, 2012 08:25 PM
shaylude01
Mar 19, 2011 03:53 PM
phase12gsr
Feb 10, 2004 10:34 PM
efvader
16
May 21, 2002 07:10 AM
