wrecked my car, now a/c won't get cold.
Sorry for the crappy title. The story goes like this:
My car was in a wreck 1 1/2 years ago (pass side front end.)
Everything was fixed but now my a/c does not get cold. The cooling fan kicks on when I hit the a/c button inside, and the RPMS jump up a bit at idle. I have good amount of pressure still (I checked the valve infront of the exhaust manifold) and no damaged lines from what I can tell.
I took it to a honda doc that did not repair a/c units though. He said the same thing everything looks good as far as he could tell.
Could I have blown a fuse to the compressor or somthing? Where are the fuses to the a/c system I have not check them yet.
Once again everything seems to be working but no cold air. I should not have to add more freon should I with good pressure? Any help would be appreciated.
do a vacuum leak test.....most places will check your a/c for free......if you pass the vac leak test......then i dunno whats wrong.....could be a bad compressor or a bad condensor......could be many things.....
shipsaeki
Apr 17, 2003 11:06 AM
