air conditioner help
Old Sep 20, 2003 | 07:03 AM
matix's Avatar
Default air conditioner help
ok I have a 94 accord. I just recharged my air. I thought i was low on freon but this wasnt it. The problem is it gets cold at night and gets a little colder while driving. when im at idle or in the heat it stays warm. I was looking at my fans and the fan on the passanger side spins like half the speed as the other one, it feels like it barely blows air. could this be the problem or is it something else. PLease help this florida heat is killing me...
Old Sep 20, 2003 | 09:01 AM
AngryTroll's Avatar
Default Re: air conditioner help (matix)
Is your air cold at highway speeds? If it does get cold, then yes, it is your faulty condensor fan giving you the problems.
No fan at idle will cause your high side pressure to rise above 400 psi. Your high pressure switch will shut down the compressor and you get warm air...
Old Sep 20, 2003 | 09:36 AM
pro1342's Avatar
The condenser fan is the one on the driver's side. If that doesn't remedy the problem, try spraying the condenser with water and see if the air gets cold, you could have a faulty condenser, too.
pktaske
Honda CR-V & Element
Jun 26, 2019 11:36 PM
SGS97EX
Aug 17, 2013 01:11 AM
jolt-tsp
Jun 27, 2006 09:01 AM
Ichigo
Jun 17, 2006 08:26 AM
