spindle problem
ok so ive had this problem on my car for a while and i think its time to fix it... my studs on my two front wheels are gone... i have a broken stud on each wheel and 2 studs that are tapped and about to break.... and i am mechanically inclined but installing studs is a bitch so i was thinking about just buying used spindles which i found easier to remove since so many of my studs are bad should i?
I would remove the hub, replace the studs that are bad/broken and then install 2 new wheel bearings in the front of the car and call it a day, killed two birds with one stone.
then just go to a tire shop i think they charge like 5-8 dollars a stud replaced i just had 2 done when i put new rubber on my car
Yeah, but its a waste of money to buy whole new spindles because you don't want to make the effort to replace a few lug studs. I don't know about anyone else here, but I sure have more time than money.
ef90b16
Nov 28, 2008 09:36 PM
HKSuperSi
Sep 13, 2007 11:05 PM
