need help with vtec in ef with b16a
Old Jul 22, 2007 | 05:21 PM
jdmhatch3's Avatar
Default need help with vtec in ef with b16a
ok guys i need help i have a 88 hatch dx model with a first gen b16a. i have no vtec lol. i have the vtec sylinoid wired into the ecu, the oil sylinoid is wired into the ecu but im running a dc 4-2-1 header with no 02 sensors but it seems to run great except for no vtec. the only code im throwing is a vss code and thats hooked up as far as i can tell. any info would be great.
thanks
Old Jul 22, 2007 | 05:27 PM
.Manny.'s Avatar
Touching My Member
Default Re: need help with vtec in ef with b16a (jdmhatch3)
Get rid of all the codes.
Any CEL will prevent the vtec from operating.
Old Jul 22, 2007 | 05:28 PM
Crx Jimmy's Avatar
if you are throwing a vss code it will not activate vtec, get it fixed and see what happens
Old Jul 22, 2007 | 05:42 PM
jdmhatch3's Avatar
Default Re: need help with vtec in ef with b16a (Crx Jimmy)
if the cable is plugged in the tranny and into the cluster and it works what else could it be?
Old Jul 22, 2007 | 05:44 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">if you are throwing a vss code it will not activate vtec, get it fixed and see what happens</TD></TR></TABLE>
x2, if your speedo is working then your vss is fine and it is your speed amplifier in your speedo gauge which means you have to replace the actual speedometer to get your vtec working again. that happened to my '90 Si last year.
Old Jul 22, 2007 | 05:50 PM
jdmhatch3's Avatar
Default Re: need help with vtec in ef with b16a (VtecSyndrome)
whats a speedo meter? and what do i do just buy a new cluster?
Old Jul 22, 2007 | 06:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhatch3 &raquo;</TD></TR><TR><TD CLASS="quote">whats a speedo meter? and what do i do just buy a new cluster?</TD></TR></TABLE>
are you serious???? what's a speedometer??? did you bump your head or something?? it's the little thing in your cluster that tells you how fast your, um.......SPEED is!! it would be cheaper to buy a used cluster than it would be to buy a new speedo unit at the dealer. until then I think you need some rest or something cause if you don't know what your speedometer is then you need to stop driving all together
Old Jul 22, 2007 | 06:12 PM
jdmhatch3's Avatar
sorry lol i had a brain fart. lmao thanks for the help man
Old Jul 22, 2007 | 06:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhatch3 &raquo;</TD></TR><TR><TD CLASS="quote">sorry lol i had a brain fart. lmao thanks for the help man </TD></TR></TABLE>
I figured, happens to us all
ewing86
21
Aug 8, 2007 05:30 PM
DA_JDM
14
May 30, 2007 08:40 AM
CRX91SE
Mar 16, 2007 07:06 AM
cates_07
13
Feb 20, 2006 08:25 AM
Rywire
Dec 27, 2002 12:30 PM
