need to swap from odb 2 to odb1 (d16y8 motor to d16z6) in 6th gen civic coupe
Old Jul 22, 2007 | 04:45 PM
ke98248's Avatar
Default need to swap from odb 2 to odb1 (d16y8 motor to d16z6) in 6th gen civic coupe
I'm unable to search for obd swap info because the search doesn't allow such a short word like "OBD" as a search keyword.
I just need to know what I will need to swap from my d16y8 (VTEC) to a d16z6 (VTEC) motor...
Thanks and my car is a 97 civic ex coupe 5spd.
Old Jul 22, 2007 | 05:24 PM
ke98248's Avatar
Default Re: need to swap from odb 2 to odb1 (d16y8 motor to d16z6) in 6th gen civic coupe (ke98248)
I'm going to turbo the d16z6, that's why i need to know how to swap the motors successfully..
Old Jul 22, 2007 | 07:54 PM
ke98248's Avatar
bump
Old Jul 22, 2007 | 09:53 PM
slowcivic2k's Avatar
Default Re: need to swap from odb 2 to odb1 (ke98248)
https://honda-tech.com/zerothread?id=2043291
That will solve the distributor wiring part of it, and this will solve the alternator part of it, if you use the OBD1 alternator. (highly suggested, the regulator is better than the OBD2 ones)
OBD2 wiring harness on your car needs to be spliced and an OBD1 round greed plug must be used.
Your wires on the engine harness are as follows:
WHT/GRN: ALT Control Signal (C)
WHT/RED: ALT Field Circuit Control (FR)
BLK/YEL: IGN Wire (IG)
WHT/BLU: Charing System Light (L)
The colors on the OBD1 plug are as follows:
WHY/YEL: ALT Control Signal (C)
BLU: ALT Field Circuit Control (FR)
WHT/BLU: Charging System Light (L)
Splice them according to the color code, and your all set.
Old Jul 23, 2007 | 06:45 PM
ke98248's Avatar
Default Re: need to swap from odb 2 to odb1 (slowcivic2k)
Thanks a million.. If you lived closer and once I got my **** together, I'd give you a ride in my 300HP+ boosted SOHC.. Fun times for a DD on drags!
dohc15
11
Aug 26, 2019 12:33 AM
roblong1962
Oct 16, 2017 06:14 PM
PinoyxEJ6
Apr 15, 2007 12:53 PM
Nick7
Apr 3, 2005 08:25 PM
Honda Kustums
16
Jul 24, 2003 12:26 AM
