Engine Sawp
Engine Sawp
I just bought a 1996 Honda Civic EX Coupe with a bad motor. I have a 1995 Civic EX Coupe motor from a car my son wrecked. Can I put the 95 motor into the 96? Sorry, I'm new to Hondas and not sure of the changes between 5th and 6th gen Civics.
Re: Engine Sawp
Replacing the D16Y8 with the D16Z6.
Replacing an OBD2 motor with an OBD1 motor.
Injectors are different, distributor is different, I belive the IACV is different. etc.
Also, D16Z6 is 16* BTDC for ignition timing while the D16Y8 is 12* BTDC if I recall.
It can be done, but you have a fair amount of work ahead of you and many little things to overcome or work around.
Also ECU for the D16Y8 I believe expects a knock sensor and the crank fluctuation sensor, neither are present on the D16Z6.
I'm sure I'm missing a thing or two in the list.
Re: Engine Sawp
do you have emissions inspections ?
if not you could just convert to obd1 to run the z6 in the 96
think you would just need a obd2a to obd1 for the ecu
then swap over the obd2 injectors, and alt to the z6
a jumper for the z6 distributor
use the 96 harness
doesn't seem too bad, but i haven't done that particular swap so i might be forgetting\missing something
use the 96 harness
bzoe1
08-03-2009 12:44 PM
dabigfunkymunky
08-11-2001 11:02 AM
