New Intake manifold spedo dont work?
Hey guys i just got finished installing a new AEBS manifold on my gsr. I take it for a drive and the spedo doesnt work. Does anybody know why? Its kinda frustrating.
i know you said you check already to see if its plugged.
now you should try to check and see if the wires are intact. check the back of the cluster, check the plug of the speed sorsor, check to see if the sensor wire has a short somewhere. what i mean to say is check everything.
one simple thing it could be too, is the sonsor itself. try switching the sensor out for a known good one(maybe from a friends car)
thanx. i checked the plug i took the sensor out it looks fine..i had the car up on jack stands and left it in 4th gear and when i wiggled the wire around the spedo moved but died again. i was wondering if u know what the wires that go to the sensor are..like which is the power ground . there are 3 wires. do u have a diagram? Thanx for your help by the way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrIntegra789 »</TD></TR><TR><TD CLASS="quote">thanx. i checked the plug i took the sensor out it looks fine..i had the car up on jack stands and left it in 4th gear and when i wiggled the wire around the spedo moved but died again. i was wondering if u know what the wires that go to the sensor are..like which is the power ground . there are 3 wires. do u have a diagram? Thanx for your help by the way</TD></TR></TABLE>
sounds like you found your problem.
pip9
28
Apr 11, 2006 04:30 PM
