Camshaft seal -trying to get out so I can replace it
Old Jul 20, 2007 | 03:06 PM
arielb1's Avatar
Default Camshaft seal -trying to get out so I can replace it
I've got the camshaft pulley off, now trying to get the seal out. Not have much luck. Do I loosen the two 10mm bolts directly above the seal to replace that seal?
thanks much
Old Jul 20, 2007 | 03:29 PM
arielb1's Avatar
Default Re: Camshaft seal -trying to get out so I can replace it (arielb1)
got it...used a tool from Harbor Frieght...a pick tool..four of them. Slowly pryed out with out loosening the bolts on top. Used a 30 mm socket to push back in after applying oil around the outer edge of the seal
Old Jul 20, 2007 | 04:17 PM
fastazzf22's Avatar
30mm bolt for a camshaft seal ???WTF
uhhh what motor was this on ?
So you just beat a seal inplace ??
Btw - Its going to leak !!
Old Jul 20, 2007 | 09:00 PM
Eddiebx's Avatar
Default Re: Camshaft seal -trying to get out so I can replace it (fastazzf22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastazzf22 &raquo;</TD></TR><TR><TD CLASS="quote">30mm bolt for a camshaft seal ???WTF
Btw - Its going to leak !! </TD></TR></TABLE>
the camshaft seal is about the size of 30mm socket or so hence why he probably suggested using that socket...... and if you dont install a press-fit seal by pressing it in to the bore, how do you propose it goes in? by telepathy?
Old Jul 21, 2007 | 04:22 PM
TouringAccord's Avatar
H-T Order of Merit
there is an easier way of doing this so you don't have to loosen the cap bolts, works for the crank seal too.
I just did this on my Civic when I did the timing belt job on it. I don't have the write-up done yet but when it is this will be included this time. I know I did it on a Civic but it'll work the same for the Accord engines.
Just take a pick, I used a scratch awl, poked it through the face of the seal and then pried it out with the scratch awl, worked great. I then used an axle nut (can't think of the size now) to install the new seal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastazzf22 &raquo;</TD></TR><TR><TD CLASS="quote">Btw - Its going to leak !! </TD></TR></TABLE>
really... and do you have a better way or do you just want to try and bash people? I've noticed a few of your posts like this.
If you have a better way of doing this then by all means please share, otherwise don't come into someones thread to not be helpful.
arielb1
Jul 21, 2007 04:45 PM
b18c inside
Jan 29, 2006 10:35 AM
escape2me
Jan 13, 2006 03:25 PM
MenaceL.A.671
Sep 22, 2004 07:13 PM
GSR44
Nov 22, 2003 07:15 PM
