Honda S2000 Honda S2000
cant change oil :(
Old Jul 19, 2007 | 02:56 PM
IntegraLs94Cam's Avatar
Default cant change oil :(
Well i was under my car trying to change my oil for the first time on my s2000 (use to have a type R). I found the bolt next to "engine oil".. i turned it counter clock-wise and the bolt would not move a bit. I pushed so hard it broke to sock wrech i was using .. i am guessing the last time honda changed my oil they over tightened it. What do you think i should do ? The car has 9,340 miles on it. it is also a 05.
Old Jul 19, 2007 | 03:08 PM
SlammedDC2teg's Avatar
Default Re: cant change oil :( (IntegraLs94Cam)
Take it back to Honda and have them change it again or tell them they over torqued it.
Old Jul 19, 2007 | 03:13 PM
Default Re: cant change oil :( (SlammedDC2teg)
the problem is that i bought the car in KY and i live in KS. I had the honda dealership down there change it before the dealer i bought the car from shipped it to me. Do you think i can take it to the honda dealership next to me and have them do it. maybe labor for free since i have the filter and oil already
Old Jul 19, 2007 | 03:45 PM
LBBP R's Avatar
it's tighten hard enough to break your wrench.... i have never heard of this... however, i have seem ppl turning wrong direction because their body is facing wrong way.
try using breaker bar or longer wrench to get the bolt out. you might need to re-tap the thread or replace the oil pan.
Old Jul 19, 2007 | 03:57 PM
avallach's Avatar
Default Re: cant change oil :( (LBBP R)
Put another wrench on the bolt and hit with rubber mallet. Don't try to muscle that thing off.
Old Jul 19, 2007 | 04:44 PM
LAS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LBBP R &raquo;</TD></TR><TR><TD CLASS="quote">it's tighten hard enough to break your wrench.... i have never heard of this... however, i have seem ppl turning wrong direction because their body is facing wrong way.
try using breaker bar or longer wrench to get the bolt out. you might need to re-tap the thread or replace the oil pan.</TD></TR></TABLE>
no matter what way you face it still turns the same way.
Old Jul 19, 2007 | 05:22 PM
wait maybe i am turned the wrong way ****.... what way do you lay under the car?? head facing to the front ? or head facing to the rear ? i think im about to feel retarded .. long day ... i douno if it matters what way your facing... i am turning it counter clock-wise
Old Jul 19, 2007 | 05:28 PM
LAS2K's Avatar
it doesn't matter what way you're facing when tightening, loosening a bolt. counter clock wise will still be the same thing 360 degrees all around the bolt.
Old Jul 19, 2007 | 06:11 PM
Rtzx9r's Avatar
GDD 1%
Default Re: cant change oil :( (LAS2K)
If he was tightening it, he would have surely stripped the bolt before the wrench broke. Not like the pan is cast iron.
Old Jul 19, 2007 | 06:31 PM
lacking vtec's Avatar
better hope ur **** aint stripped. my car was leakin oil when i bought it only to find out the previous owner stripped the oil pan. i had to change it all.
Old Jul 19, 2007 | 07:35 PM
Default Re: (lacking vtec)
im going to take it in the dealership and have them do it... hopefully they dont mess it up.. or it is the other honda's fault
Old Jul 19, 2007 | 08:44 PM
LBBP R's Avatar
i usually lay front to rear of the vehicle.. so i end up turning clock-wise to loosen the bolt. by doing this way, i don't get oil on my face. so thumbs down to yourself
Old Jul 19, 2007 | 08:57 PM
b20integrapower's Avatar
Technically the bolt will always be turned counter-clockwise, but it may seem opposite from the perspective point you are at.
Old Jul 20, 2007 | 12:31 AM
mister x's Avatar
Default Re: cant change oil :( (b20integrapower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">Technically the bolt will always be turned counter-clockwise, but it may seem opposite from the perspective point you are at.</TD></TR></TABLE>
Except below the equator, where it's the reverse.
Bstorm
16
May 27, 2010 10:36 AM
turq93t
25
May 15, 2005 01:21 PM
sonicrex
Jan 21, 2005 01:27 PM
gtpsleeper
Dec 26, 2004 09:29 PM
rscstarr
Acura TL, RL & ZDX
Feb 16, 2003 11:37 AM
