Can I throw a EX Gearset in a DX Trans?
Old Jul 18, 2007 | 05:50 PM
JMelt4's Avatar
Default Can I throw a EX Gearset in a DX Trans?
I have a DX Transmission (1995) laying around that I would like to swap in an EX/Si gear set and higher FD, maybe even an LSD. Is this possible? Are certain transmissions are better than others for swapping gears? This is for a D-series of course. Thanks!
Old Jul 18, 2007 | 08:35 PM
JMelt4's Avatar
Default Re: Can I throw a EX Gearset in a DX Trans? (JMelt4)
bump for quick answer
Old Jul 18, 2007 | 10:16 PM
Mista Bone's Avatar
D Tranny Guru
Possible, but expensive.
The LSD is gonna cost over $1000 with parts.
You also have to be careful with different sozed bearings on the countershaft, then you'll have to reshim the mainshaft.
Just buy a EX/Si tranny, easier than butchering up two trannys and neither of them working right.
Old Jul 18, 2007 | 10:19 PM
DecentCivicZ6's Avatar
B A N N E D
Default Re: (Mista Bone)
yep, just like he said...all the bearings are smaller and housings in the DX tranny
Old Jul 18, 2007 | 11:56 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
wrong, i put all the internals of a si tranny into my dx tranny, its just i had to use the dx bearings cuz si dont fit when you put casing on, so yes it will work but use dx bearing, and i have an si tranny casing with no internals for sale CHEAP hit me up
Old Jul 19, 2007 | 03:54 AM
sohc-8's Avatar
Default Re: (DOHCgarage919)
just wondering why didn't you just install the si tranny instead of putting all the si internals in the dx. i was thinking the casing was bad or something, but you are selling casing??????
Old Jul 19, 2007 | 04:36 AM
instructor74's Avatar
you want to know what trans parts will work with what gear set ask the master Im a guy on here his screen name is bense
Old Jul 19, 2007 | 06:29 AM
speedooo's Avatar
Default Re: Can I throw a EX Gearset in a DX Trans? (instructor74)
why not just use the ex/si tranny
Old Jul 19, 2007 | 10:16 AM
Default Re: (sohc-8)
i didnt use the si trans becuz the casing i had already was polished the si trans was dirtyyy and the si trans forks were broken
Old Jul 19, 2007 | 01:02 PM
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 &raquo;</TD></TR><TR><TD CLASS="quote">wrong, i put all the internals of a si tranny into my dx tranny, its just i had to use the dx bearings cuz si dont fit when you put casing on, so yes it will work but use dx bearing, and i have an si tranny casing with no internals for sale CHEAP hit me up </TD></TR></TABLE>
wrong? wtf is wrong???? no1 said it couldnt be done, said the bearings are all diff sizes...they have bigger bearing in the ex/si tranny for a reason, higher rpm all the time = bearing spinner faster than the dx...thats why bigger bearing...go ahead and put the ex/si in there..and watch how long the bearings dotn last....im sure they put bigger ones in there for a reason. thats why i Used my CRACKED ex housing still over the DX...expletive those small *** bearings. but no1 said it couldnt be done, so NOTHING is wrong
Old Jul 19, 2007 | 01:46 PM
JMelt4's Avatar
Default Re: (DecentCivicZ6)
That is exactly the info I needed! Thank you! I wont' use the DX tranny, no way.
Old Jul 19, 2007 | 02:31 PM
dude my tranny is fine been running for 3 years with dx bearings you dont have any experience so you shud stfu it works cuz ive done it and my tranny is good and still runs after all the abuse i put on it
Old Jul 19, 2007 | 03:11 PM
JBrettHowell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">you want to know what trans parts will work with what gear set ask the master Im a guy on here his screen name is bense</TD></TR></TABLE>
Yeah, that Mista Bone guy is a hack!
Old Jul 20, 2007 | 12:46 PM
Mista Bone's Avatar
D Tranny Guru
JBH, long time no post/see......
Bense started as a student of mine........
Student almost as good as his master, I've still with held a few tricks, but his is the only person that I've shared my shimming trick with.
He's been detoured by some F2B BS, might have lost his tranny edge
JFWY Bense
Jdm03
13
Aug 15, 2011 08:01 AM
Crossbreeder
14
Sep 2, 2009 06:19 PM
Don E
21
Sep 19, 2006 04:36 AM
tblofsky
Apr 10, 2006 06:54 AM
94dxt
Jun 10, 2003 09:58 AM
