someone help me out!!
Old Jul 18, 2007 | 03:53 PM
b20vteclsintegra's Avatar
Default someone help me out!!
ok i have a ek hatch and almost everytime i brake it makes a poping sound coming for the front suspenion. i have not had time to get under the car and check it out yet. can anyone tell me what i might be??? let me know thanks
Old Jul 18, 2007 | 03:59 PM
BlackoutVTi's Avatar
Default Re: someone help me out!! (b20vteclsintegra)
The only thing this can remind me of would be when I sent my car in to get the suspension worked on by someone else for the first time. They put in a camber kit and aligned it, but forgot to put a codder pin through the castle nut on my upper control arm when they reattatched it, and it unscrewed itself while I was on the road. Made a clunk sound when I hit the brakes about three times, then fell off and fucked my car up.
Check your castle nuts for codder pins; They're $.05, nothing parts, but they matter a whole lot.
Old Jul 18, 2007 | 09:09 PM
therujan's Avatar
wow old thread but.,,
i have a 93 civic automatic for a good 1 year
i have the similar problem
when ever i break and the engine down shifts automatically there is a small popping
sound coming out of the front left corner ( more like between door & wheel )
I've got pretty used to it... but it never gave me any sort of mechanical problems nor handling issues so I've just ignored it...
just to let you know that you are not alone!!! i am with you buddy
Old Jul 18, 2007 | 09:31 PM
daluv's Avatar
Default Re: someone help me out!! (therujan)
Might be a control arm bushing. I had that popping sound in my 93 when I first got it. Jacked the car up, saw that the factory lower control arm bushings were about shot as could be. Got some polyurethene bushings for the lower control arms from energy suspension, and the sound went away after I put the poly bushings in. Jack the car up and see how yours are.
Old Jul 22, 2007 | 02:43 PM
Default Re: someone help me out!! (BlackoutVTi)
thanks i will check that out for sure.
Old Jul 22, 2007 | 04:48 PM
egb16pg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daluv &raquo;</TD></TR><TR><TD CLASS="quote">Might be a control arm bushing. I had that popping sound in my 93 when I first got it. Jacked the car up, saw that the factory lower control arm bushings were about shot as could be. Got some polyurethene bushings for the lower control arms from energy suspension, and the sound went away after I put the poly bushings in. Jack the car up and see how yours are.</TD></TR></TABLE>
yea i was thinking the same
Old Jul 22, 2007 | 04:52 PM
slowcivic2k's Avatar
Default Re: someone help me out!! (egb16pg)
Make sure that your caliper mounting bolts are all in there, when you hit the brakes it will hit against the rim, someone thought it would be cool to play that joke on me...
Old Jul 23, 2007 | 06:05 AM
Default Re: someone help me out!! (slowcivic2k)
wow that would be a great joke. NOT but thanks i will check that out 2.
Lightsped
Honda Civic (2001 - 2005)
Apr 14, 2013 05:39 AM
luder916
10
Aug 23, 2008 09:07 AM
track_assassin
11
Jan 26, 2006 03:38 PM
philosofy1
Jan 26, 2006 05:44 AM
bones_accord
Feb 13, 2003 05:29 PM
