Dist. rotor stuck on shaft
Old Jul 18, 2007 | 03:41 PM
dcdcdc's Avatar
Default Dist. rotor stuck on shaft
Are there any ways out there to take this metal piece of the rotor off of the shaft. I completly broke off all the plastic parts of the rotor doing the replacement and can't get this piece off. Theres rust around it and I have let it soaked in PB blaster for awhile and still cant pull it off. TIA
Here are some pics to help visually:
Old Jul 18, 2007 | 03:51 PM
Cheeze's Avatar
Default Re: Dist. rotor stuck on shaft (dcdcdc)
If you have a small extraction pulley..you should be able to get that off...if worse comes to worse...I would chisle it off..
Old Jul 18, 2007 | 03:54 PM
dcdcdc's Avatar
Default Re: Dist. rotor stuck on shaft (Cheeze)
i dont have the extraction pully and not enough space to get a chisel behind there to chisel that piece 'outward'. thanks though
Old Jul 18, 2007 | 03:59 PM
Cheeze's Avatar
Maybe if you try to make a cut with a flat head or something on one side of it then pry it open to get it to loosen up and may be able to pry it up?
Old Jul 18, 2007 | 04:09 PM
EARLdaSQUIRREL's Avatar
official honda whore
put a flathead underneath it and pry it up
Old Jul 18, 2007 | 04:12 PM
dcdcdc's Avatar
Default Re: Dist. rotor stuck on shaft (coptzer)
tried that too
Old Jul 18, 2007 | 04:30 PM
BMaDOHC's Avatar
grab the piece tightly with vise grips and chisel at the edge of the vise grip were its clamped to the piece.
Old Jul 18, 2007 | 04:45 PM
dcdcdc's Avatar
Default Re: Dist. rotor stuck on shaft (BMaDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMaDOHC &raquo;</TD></TR><TR><TD CLASS="quote">chisel at the edge of the vise grip were its clamped to the piece.</TD></TR></TABLE>
I dont understand this, how will that make the piece come off. Please ellaborate
Old Jul 18, 2007 | 05:22 PM
dcdcdc's Avatar
thanks to all that replied, got it off finally
dcdcdc
Dec 6, 2015 02:33 AM
belairbrian
10
Mar 1, 2013 06:14 PM
alcor4ever
Dec 19, 2011 03:36 PM
Homesickelian
Dec 9, 2006 09:20 AM
93H22ACX
May 24, 2004 02:32 AM
