Low Vtec Oil Pressure!!!! Need Help
Old Jul 17, 2007 | 07:58 PM
4door hobo's Avatar
Default Low Vtec Oil Pressure!!!! Need Help
Ok i have a ls/vtec build that i finished last month and the only problem i cant figure out is the vtec, the problem is i have low oil pressure, i put a sending unit at the oil vtec port on front of the head so i can watch the pressure when it hits, strange thing is when the car is cold it hits ok, about 60 psi in all the gears, but when at operating temp its about 25 and you can hear the solenoid kick in and out a few times before the cel turns on and its has 16 ohms so its good according to the book.
Im using the GE kit, the oil pressure to the head is good, i have a type r oil pump and there should be plenty of oil. i cleaned the vtec screens and everything is good the lost motion assy are in great shape and i even hooked up vtec to a switch in the cab by just putting 12 to the solenoid and bypass the oil pressure switch, and same thing hits when cold but after its warm less that 25, i have been screwing with this thing for a while and cant get it right, if there are any guru's that have any idea please let me know, i have tried almost everything in the book, Thanks
Old Jul 18, 2007 | 02:16 PM
4door hobo's Avatar
Default Re: Low Vtec Oil Pressure!!!! Need Help (4door hobo)
Old Jul 18, 2007 | 04:44 PM
rextec's Avatar
im stummped! it has to be a missing o-ring or a leak of some kind somewhere.
bump
Old Jul 19, 2007 | 07:10 AM
G.Benen's Avatar
Call Dave from Defcon-Racing 1-416-803-3589
Old Jul 19, 2007 | 08:07 AM
DARKB20's Avatar
you are in so-cal, go see Eugene at
Old Jul 19, 2007 | 11:50 AM
4door hobo's Avatar
Default Re: Low Vtec Oil Pressure!!!! Need Help (DARKB20)
Thanks ill give them a shot
Old Jul 22, 2007 | 11:19 PM
4door hobo's Avatar
i think it might be the oil pan or the pick up tube, im going to pull it on wensday and check it out,
Old Jul 30, 2007 | 07:53 PM
4door hobo's Avatar
turns out it was the oil pan, i bought one from my work at <U>AutoZone</U> made the pick up tube hole larger where it sits in the oil and now i have 80psi in vtec, i had only a small dent, but now everything is perfect.
StolenTeg
Oct 8, 2007 02:41 PM
4door hobo
Jul 30, 2007 07:53 PM
Turbocivic94
Jun 10, 2003 07:11 PM
zdr262
Oct 23, 2001 09:29 PM
zdr262
Oct 23, 2001 01:51 PM
