When car gets hot no vtec, Please help
Old Jun 1, 2003 | 06:37 AM
Turbocivic94's Avatar
Default When car gets hot no vtec, Please help
my vtec works for about 5 min when i start the car and then it stops working. It gives me cel 22 and I already changed the vtec pressure switch and same problem. What would cause this to happen.
Thanx in advance
Old Jun 1, 2003 | 07:22 AM
soundman's Avatar
What kind of oil are you using? You might not be getting enough pressure to the solenoid.
Old Jun 1, 2003 | 07:49 AM
DR. ON POINT's Avatar
Banned
Default Re: (soundman)
see if u have enoguh oil in ur car
Old Jun 2, 2003 | 09:30 AM
I'm using 10w-40 and it has enough oil. I check oil everyday. the oil is on the second line. any other suggestions
Old Jun 2, 2003 | 10:31 AM
soundman's Avatar
You need to see what kindof oil pressure you're getting to the solenoid. It sounds like oil pressure.
Old Jun 2, 2003 | 10:51 AM
VaporTrail's Avatar
New User
Default Re: When car gets hot no vtec, Please help (25 PSI CRX)
no VTEC or it's breaking up? Could possibly be the ignitor going bad...
Old Jun 2, 2003 | 10:54 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: When car gets hot no vtec, Please help (VaporTrail)
Check the dowel ring under your #3 cam cap
Old Jun 2, 2003 | 06:45 PM
sometimes no vtec and sometimes its breaking up. which means I should change the distributor. It gives me 2 cels 8 & 22.
you guys think it can be oil pump. I'm getting 0 pressure on idle. does not seem normal
Modified by 25 PSI CRX at 3:27 AM 6/9/2003
Old Jun 9, 2003 | 04:19 PM
changed oil pump today and same problem. oil pressure still drops to 0 psi after driving the car for 5 minutes. what could be the problem
Old Jun 9, 2003 | 05:30 PM
boostin b16's Avatar
Default Re: When car gets hot no vtec, Please help (SIXTYdashONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">Check the dowel ring under your #3 cam cap</TD></TR></TABLE>
my first thought... that can cause significant drops in oil pressure to the head. your oil pump could possibly be going bad also?
Old Jun 9, 2003 | 06:20 PM
turbodGSR's Avatar
Default Re: When car gets hot no vtec, Please help (boostin b16)
there are little dowels inside the rocker assembly. if on of them are out then low pressure, but it sounds like bearings if u have 0 oil pressure
Old Jun 10, 2003 | 08:19 AM
I changed the oil pump already and checked the dowel pin. I can't figured it out unless my main bearings are shot. the motor only have 2300 since rebuilt. Everything is new in the motor.
Old Jun 10, 2003 | 11:33 AM
GreddySi99's Avatar
I would install a oil pressure gauge if it says 0 then I would pull the oil pan and check your bearing clearances using plasti gauge you can get it at napa. If the oil clearances are to large you will see low to no oil pressure. If the bearing do not look trashed and you have no oil pressure then whoever built your engine fucked up on sizing the bearings. that is all folks
Old Jun 10, 2003 | 07:11 PM
Default Re: When car gets hot no vtec, Please help (intercooledJRSC)
took main bearings off and one of them is shot. gonna change them and see what happens. hopefully that would fix the problem.
PH3593A
11
Jul 19, 2023 02:36 AM
prime-R
26
Jun 4, 2011 11:32 AM
4door hobo
Jul 30, 2007 07:53 PM
DC2TEGGA-GSR
Jan 19, 2006 05:04 PM
mt23vtecbb2
Aug 22, 2003 01:22 PM
