97 honda civic tranny problem
Old Jul 17, 2007 | 02:14 PM
undertaker_46's Avatar
Default 97 honda civic tranny problem
Ok here is the story: I got this 97 civic for real cheap (don't have much money) it was crashed in the front. I straighten it out (Work at a body shop). The engine(d16y7) works fine it starts with a push of a button(remote start, it starts with the key as well) but for some reason I tried to drive the car and in drive it gives me a loud grinding sound. Tranny shifts good, reverse is good but drive seems to be the problem. I got a used tranny from a friend from a 95 civic b15y6. At first it looked the same but when I took a closer look the tranny is missing 2 solonoid packs and it has a throttle valve cable on it. Will this tranny work correctly with out burning the clutch? (He cut the cables for the gear shift and throttle/tv) both transmissions are automatic.
Old Jul 17, 2007 | 03:52 PM
EL Vap133's Avatar
Default Re: 97 honda civic tranny problem (undertaker_46)
Wait, sdo you have an auto or manual tranny?
Old Jul 19, 2007 | 12:38 PM
yes both transmission are automatic.
Old Jul 19, 2007 | 03:11 PM
EL Vap133's Avatar
I don't understand, how are you going to "burn a clutch" if you don't have a manual tranny?
Old Jul 19, 2007 | 06:59 PM
Default Re: 97 honda civic tranny problem (EL Vap133)
all transmissions have clutches. I was reading an article about the difference between the cable throttle for the transmissions and the solenoids paks. I just wanted to know if it would work without having the cable connected because I still have a throttle body that only have enough space for the gas pedal.
PrOxY_KiLLeR
Aug 26, 2010 04:35 PM
Fastasscar
Jun 20, 2009 04:29 PM
Jekzfab
Oct 30, 2008 10:58 PM
hmtcrxsir
Sep 28, 2008 11:06 AM
Cractos
11
Aug 26, 2004 10:33 PM
