Check Engine from nowhere ...
Car is 1996 Del Sol S with D16Y7 stock. I was having a cig last night and started a car ... while idling all of a sudden car bogged and check engine light came on. RPM went up to about 1K and stayed there ... Today I wanted to check at local Advanced auto parts what is the code it's throwing but supposedly they don't check codes anymore in all sorts of typical stores [autozone, advanced, kragen]. Since I had to go to work I left. I can feel hesitation and bogging when accelerating from the stop untill about 2K -2.3K then it goes normally ... On 1st gear it actually jumps fast after it passes "bogging" phase. and it goes quite normal thru all the gears. I jumped my service conector but only thing I got was 3 fast blinks. It's an OBD2 car so I know best way would be to scan it for codes with the tool but what I found out so far that it could be MAP sensor ... checked for connection and it's there ... any suggestions?
Mike
Mike
Code 3 is your MAP sensor. Test your plugs if they are bad then replace them. If not then it may be the MAP itself and you'll need to replace it.
I got full tuneup done recently ... new plugs, rotor, cap, fuel filter, air filter, belts, water pump, timing belt and even lower motor mounts that were cracked ... not the plugs ... got brand new NGK in there ... fire away ... with ideas ... where to get stock MAP sensor for best price in case thats the issue .. any vendor suggestions ... rock auto got them for about $50 bucks
3 fast blinks is a code 3 for map sensor
is your map sensor a firewall mount or a throttle body mounted sensor?
i have both laying around here, ill sell them cheap if you can use them.
Well ... on my way back home I drop by Auto Zone and voila ... got my code P0108 .. MAP sensor circuit high voltage. I guess then best option will be just new MAP sensor and call it a day ... cant see a reason why it would "Just fail' with no warning ... I have checked it today and all the vacum lines also ... Probe tested connector ... 4.78V or something like that. Just makes me wonder that it happened after a full tuneup recently ... I got like 300 miles on new water pump and timing belt but thru that 300miles everything was purrfect ... I even got myself valve adjustment done last sunday ... I guess it's just a misshap ... any thoughts?
Mike
Mike
BeanRacer
Nov 24, 2001 11:15 AM
